Removing flux?
Old July 18th 10, 02:20 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Removing flux?
I'm doing some brazing and would like to remove the solid cake of
flux that forms around the braze.
How do I remove that flux?
Mechanical or is there a chemical? - Mike
Old July 18th 10, 03:33 PM posted to rec.aviation.homebuilt
GeorgeB
On Sun, 18 Jul 2010 08:20:32 -0400, Michael Horowitz
In my experience, most brazing flux used with steel may be removed
with water. In the days when I did some, an old toothbrush and warm
water did the trip.
What flux are you using? The manufacturer (well, name on the jar)
probably has cleanup procedures.
Old July 18th 10, 04:00 PM posted to rec.aviation.homebuilt
Michael Horowitz
I see where it says to quence in hot water; I"ll give it a try - MIke
water did the trip.
Old July 19th 10, 03:51 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Quenching is how it is to be rapidly cooled. Look again to see if there is
anything about cleanup and inspection after the weld.
Old July 21st 10, 01:00 AM posted to rec.aviation.homebuilt
jim wynhoff
Quenching is how it is to be rapidly cooled. *Look again to see if there is
I'll be following this thread. In 40 years of welding and brazing,
I've never found a GOOD way to remove the glass-like residue from
brazing flux. At one place I worked, they used bare (unfluxed) rod,
and had a flux pot between the Acetylene tank and the torch.
Interesting green flame, great fluxing action, and almost zero
residue.
Old July 21st 10, 03:49 AM posted to rec.aviation.homebuilt
I'm working on the fuel system for my homebuilt and I need 1.5 psi or
less fuel pressure.
I'm thinking "remote float bowl" gravity feeding the ex Harley carb,
and either a rear floatbowl from a single-pumper Holley 4bbl
(preferably center float) or the floatbowl from an SU HS8.
Anyone on the list in east central Canada (sw ontario) have either
floating around (no pun intended)
Removing RTV John Home Built 6 October 31st 06 11:07 PM
Removing Ethanol from Gas? Jay Honeck Piloting 67 August 16th 06 04:29 PM
Removing the coatings? Michael Horowitz Home Built 1 October 8th 05 10:32 PM
Turbo Lance MP flux ? John Doe Owning 3 September 28th 05 02:56 AM
Sources for Yellowed tagged Remote Gyro and Flux Gate. Michelle P Owning 0 July 18th 04 01:19 AM
