A-6 Radar Display?
Old September 25th 04, 12:03 AM
Nick Coleman
Default A-6 Radar Display?
Just started re-reading Coont's Flight of the Intruder, and his
description of the capabilities of the terrain radar is interesting.
Early in the book he describes a training flight through canyons and
valleys in IMC, using the radar for avoidance.
I'm curious what the BN would actually see in his scope? Would it be a
like a line drawing of the terrain (quite visual and not needing much
interpretation) or would it be more like a staticy TV with 'blobs' that
needed skill to interpret what they represented? Or something else
completely, like an oscilloscope type of display?
Thanks in advance. Tried googling, but didn't really know what to
search for.
Nick
Old September 25th 04, 03:04 AM
Mike Kanze
Nick,
I've loaned out my copy of FOTI so I can't immediately refer to it in trying
to answer your question. Try I will, though.
First, the setting for FOTI is the later years of the VN conflict. This is
important because the A-6A was the current Intruder model at that time. The
A-6E had not yet entered fleet service and some of the whistles and bells of
the A system were eliminated or very greatly changed in the E system -
including a couple of terrain-clearance toys that Coonts likely describes in
FOTI.
Second, one must remember that the A-6A was the "first" of its kind - the
first aircraft with full integration of its various sensors into a digital
(not analog, like the Norden bombsight) computer. In this respect it was
also very much "bleeding edge." The personal computing dictum about being
especially wary of Version 1 of anything could as well have been written by
those of us in the A-6A.
Search Radar Terrain Clearance
One terrain clearance toy was a feature called Search Radar Terrain
Clearance (SRTC). As its name implies, SRTC used the A's AN/APQ-92 search
radar to generate a synthetic terrain display on the pilot's Vertical
Display Indicator (VDI), the very large cathode ray tube (CRT) display in
the center of the pilot's console, right under the gunsight. The synthetic
display showed vertical terrain development in a 53 degree by 26 degree
window about the projected flight path. For example, if the Intruder was
heading for a valley between two hills, the pilot would see return generally
in the shape of two hills (one on either side of the display), with a
curving "V" notch in the center between them. (This is somewhat difficult
to describe without a graphic.) The return would slide "down" toward the
bottom of the VDI as the flight progressed and radar return for these
terrain features was processed.
The B/N would not normally monitor the VDI, unless he happened to look over
at the pilot's console. Instead the same radar return was presented on the
B/N's Direct View Indicator (DVI), the CRT in the center of the B/N's
console as a Plan Position Indicator (PPI) information covering an arc of
about 50 degrees and a range of about 27 miles. (A PPI display looks like a
slice of pie whose point is at the bottom of the DVI. The "point" of the
pie slice is where your aircraft is now and the 50 degree arc covers the
terrain ahead of the projected flight path.) PPI information does not give
the crew any indication of terrain elevation so its use alone for terrain
clearance monitoring was not conducive to mission prosecution or crew
longevity. g
By the time I completed type training in the A-6 (1972), we were not using
or receiving significant training with SRTC. The primary reason for this
was
SRTC's inability to detect smaller man-made features - like cables that the
bad guys could suspend across a valley. Every now and then, though, we'd
light up SRTC especially if we were flying a training route like Whidbey's
OB-16 whose features were well-known and for which both crew would establish
a mutually agreeable safety margin. (Humorous example: "300 additional
feet of clearance for each wife, plus 100 additional feet for each kid.")
Elevation Scan
Another feature in the A was Elevation Scan (E-scan). With E-scan the A's
AN/APQ-112 track radar was used to generate vertical terrain development on
the Pilot's Horizontal Display (PHD) the CRT immediately below the VDI on
the pilot's side. The pilot read vertical development "left to right" on
the PHD, with obstructions closer to the aircraft appearing on the left side
of the PHD and those at greater range lying more to the right. (Again, I
apologize. This is hard to describe without a graphic.) E-scan return
would gradually slide from right side of the display (farther away) to the
left (closer) as the flight progressed and new return for the same terrain
was processed. The information displayed on the PHD in E-scan also included
a flight path line and a clearance line. The pilot would scan both the VDI
and the PHD while flying in E-scan mode, performing the necessary spatial
interpretation gymnastics to deduce how close the A was to a possible prang.
The B/N could not observe E-scan on his DVI. His viewing pleasure was
limited to search radar input, usually shown as PPI information while the A
was in E-scan mode.
Like SRTC, E-scan's day had passed by the time I reached type training - if
in fact it ever had a "day" to enjoy. Aside from being a clumsy way of
figuring out how close to pranging you might be, E-scan was further limited
by the track radar's relatively poor reliability.
Hope this helps.
Mike Kanze
"Owl", B/N
A-6A, A-6B (PAT ARM), KA-6D
"Nick Coleman" wrote in message
search for.
Nick
Old September 26th 04, 09:16 AM
Nick Coleman
Many thanks for this very detailed explanation, Mike. I can visualise
exactly what you are saying when reading the book.
(The episode I mentioned is on p 33 of the hardback edition, where Jake
is remembering a training flight in which Morgan is giving a running
commentary from his scope and then saves their lives by looking into
his scope* and screaming, "Pull up" after Jake had relaxed and
forgotten his scan. Sounds like Coonts may have used a bit of poetic
licence in giving the BN's scope elevation info.)
Thanks again,
Nick
* Coonts' terminology
Mike Kanze wrote:
Nick,
trying
This is
time. The A-6E had not yet entered fleet service and some of the
whistles and bells of the A system were eliminated or very greatly
changed in the E system - including a couple of terrain-clearance toys
that Coonts likely describes in FOTI.
the first aircraft with full integration of its various sensors into a
digital
was also very much "bleeding edge." The personal computing dictum
about being especially wary of Version 1 of anything could as well
have been written by those of us in the A-6A.
search radar to generate a synthetic terrain display on the pilot's
Vertical Display Indicator (VDI), the very large cathode ray tube
(CRT) display in
synthetic display showed vertical terrain development in a 53 degree
by 26 degree
was heading for a valley between two hills, the pilot would see return
generally in the shape of two hills (one on either side of the
display), with a
difficult to describe without a graphic.) The return would slide
"down" toward the bottom of the VDI as the flight progressed and radar
return for these terrain features was processed.
over
on the B/N's Direct View Indicator (DVI), the CRT in the center of the
B/N's console as a Plan Position Indicator (PPI) information covering
an arc of
like a
the pie slice is where your aircraft is now and the 50 degree arc
covers the
give the crew any indication of terrain elevation so its use alone for
terrain clearance monitoring was not conducive to mission prosecution
or crew longevity. g
using
this was
that the
we'd light up SRTC especially if we were flying a training route like
Whidbey's OB-16 whose features were well-known and for which both crew
would establish
additional feet of clearance for each wife, plus 100 additional feet
for each kid.")
Elevation Scan
A's AN/APQ-112 track radar was used to generate vertical terrain
development on the Pilot's Horizontal Display (PHD) the CRT
on the PHD, with obstructions closer to the aircraft appearing on the
left side
(Again, I
return would gradually slide from right side of the display (farther
away) to the left (closer) as the flight progressed and new return for
the same terrain
included
the VDI and the PHD while flying in E-scan mode, performing the
necessary spatial interpretation gymnastics to deduce how close the A
the A was in E-scan mode.
- if
of figuring out how close to pranging you might be, E-scan was further
limited by the track radar's relatively poor reliability.
Hope this helps.
Nick
Mandrake 9.2
KDE 3.1.3
Old September 26th 04, 11:48 AM
Nick Coleman
As an aside, I forgot to mention this book was one of the seminal reads
of my life. I know that sounds corny, but occasionally a book or a
movie comes out that changes the way you see the world.
The two first 'practical' books I read about Vietnam were 'Chickenhawk'
and FOTI. I was just a youth during Vietnam and everything I'd read
before was dry and historical. These two books brought the common
aviator to life.
I sometimes wonder what eventually happened to the author of
Chickenhawk; did he make it in his life afterwards or not.
Nick
Old September 26th 04, 02:17 PM
Guy Alcala
Nick Coleman wrote:
snip
You can read the sequel, "Chickenhawk: Back in the World" and find out.
See
http://www.robertcmason.com/Books/chbitw.html
Guy
Old September 27th 04, 03:18 PM
Pechs1
spam bucket- The two first 'practical' books I read about Vietnam were
'Chickenhawk'
aviator to life. BRBR
'Everything we had'-Al Santoli
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Old September 27th 04, 10:58 PM
Mike Kanze
Nick,
Got back my copy of FOTI this weekend and turned to the segment you mention.
From Coonts' narrative, the route sounds a bunch like the OB-16 route.
IIRC, OB-16 started in northern Oregon and ended at the B-16 nuclear
bullseye at NAS Fallon, NV. The early legs of this route took one into the
canyons of the John Day River system, including one particular canyon that
runs almost exactly N-S. After watching canyon walls go by for about 20 nm,
the terrain begins to broaden and you change course to roughly SSE for a ~70
nm leg to Harney Lake. The few charts I saved of this area confirm the
existence of some low hills and shallow valleys along this otherwise
flattening route. I would guess these are the hills Coonts was visualizing
as threats to Jake and Morg when he wrote this segment.
(For those among you who are limited to the likes of a Rand-McNally road
atlas, the route starts at a little burg named Kimberly which is about 60 nm
SSW of Umatilla, OR.)
There's no specific thing that Coonts mentions in his narrative that would
cause Morg to scream for a pull-up. Morg has just put his head back into
the hood, so he is not looking at the pilot's VDI. (Neither apparently is
Jake, since he is not maintaining the 1,000 feet of clearance he has cranked
into the VDI's offset impact bar.) Since Jake is viewing SRTC on the VDI,
Morg is limited to a PPI display on his DVI. Morg may have noted a
way-too-strong radar return too close-in for comfort. Or maybe things just
"didn't look right" to him, the sound of that little voice we all carry
within us. Or maybe this was just some artistic license taken by Coonts.
Night or IMC conditions are absolutely the most demanding environment for
low-level flight. Jake clearly has let his scan deteriorate away from the
SRTC info and (as the narrative states) dwell too much upon other things
like engine instruments and fuel state. Unless you're heading directly for
a canyon wall, your radar altimeter readings do not deteriorate from 1,000
feet to 100 feet in only an instant.
Coonts' narrative is one of many good examples of the value of having two
pairs of eyeballs sitting side by side. For attack work - including
low-level, all wx ops - this was the gold standard of that era. The
situational awareness such an arrangement facilitates - and demands - of
both pilot and B/N undoubtedly saved many a mission, bird and crew.
Mike Kanze
"It was like being a rat living under a bowling alley."
- Willem Dafoe, commenting on what it was like to sleep in a compartment
just below the flight deck of an aircraft carrier.
Thanks again,
Nick
Mike Kanze wrote:
Nick,
trying
This is
digital
(CRT) display in
by 26 degree
display), with a
over
an arc of
like a
covers the
using
this was
that the
would establish
for each kid.")
Elevation Scan
left side
(Again, I
the same terrain
included
- if
Hope this helps.
Nick
Mandrake 9.2
KDE 3.1.3
Old September 28th 04, 01:29 AM
Mike Kanze
Nick,
pairs of eyeballs sitting side by side for attack work. For low-level, all
wx ops this was the gold standard of that era. The
Mike Kanze
Thanks again,
Nick
Mike Kanze wrote:
Nick,
trying
This is
digital
(CRT) display in
by 26 degree
display), with a
over
an arc of
like a
covers the
using
this was
that the
would establish
for each kid.")
Elevation Scan
left side
(Again, I
the same terrain
included
- if
Hope this helps.
Nick
Mandrake 9.2
KDE 3.1.3
Old September 28th 04, 03:35 AM
Mike Kanze
Nick,
Mike Kanze
Thanks again,
Nick
Mike Kanze wrote:
Nick,
trying
This is
digital
(CRT) display in
by 26 degree
display), with a
over
an arc of
like a
covers the
using
this was
that the
would establish
for each kid.")
Elevation Scan
left side
(Again, I
the same terrain
included
- if
Hope this helps.
Nick
Mandrake 9.2
KDE 3.1.3
Old September 30th 04, 01:04 AM
Nick Coleman
posted & mailed
Mike, thanks for the details and for taking the time to do it. I can't
really add much because you've said everything g.
Enjoy reading this stuff from the guys who have actually done it; much
appreciated.
Nick
Mike Kanze wrote:
Nick,
mention.
into the canyons of the John Day River system, including one
20 nm, the terrain begins to broaden and you change course to roughly
SSE for a ~70
the existence of some low hills and shallow valleys along this
otherwise
visualizing as threats to Jake and Morg when he wrote this segment.
road atlas, the route starts at a little burg named Kimberly which is
about 60 nm SSW of Umatilla, OR.)
would
into
apparently is Jake, since he is not maintaining the 1,000 feet of
VDI,
just "didn't look right" to him, the sound of that little voice we all
carry
Coonts.
for
the SRTC info and (as the narrative states) dwell too much upon other
things
directly for a canyon wall, your radar altimeter readings do not
deteriorate from 1,000 feet to 100 feet in only an instant.
two
of both pilot and B/N undoubtedly saved many a mission, bird and crew.
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
B-52 crew blamed for friendly fire death Paul Hirose Military Aviation 0 March 16th 04 01:49 AM
Ham sandwich navigation and radar failure David Brooks Instrument Flight Rules 47 December 31st 03 01:15 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 07:17 PM
