carbon fiber wing wheel dolly
Old July 26th 10, 10:04 AM posted to rec.aviation.soaring
gonz
Default carbon fiber wing wheel dolly
nice design for this wing wheel dolly
carbon fiber texalium
shock absorber
easy to use
watch the video http://www.youtube.com/watch?v=djXBxx9ys_Y
Old July 28th 10, 02:15 AM posted to rec.aviation.soaring
Bob Kuykendall
shock absorber
easy to use
watch the video * * * *http://www.youtube.com/watch?v=djXBxx9ys_Y
Looks neat, maybe I'll make one for myself.
Thanks, Bob K.
Old July 28th 10, 02:22 AM posted to rec.aviation.soaring
Brad[_2_]
shock absorber
easy to use
Thanks, Bob K.
Tom and I are already thinking the same thing. Carbon fiber sleeve
over a EPS foam rod?
Brad
Old July 28th 10, 04:42 AM posted to rec.aviation.soaring
Dave Nadler
shock absorber
easy to use
Why would you use a big ugly coil spring,
when you can easily make the arm springy ?
Needs no loose parts and easier attach,
just because a girl can do it doesn't mean
a glider pilot can....
See ya, Dave
Old July 28th 10, 07:14 AM posted to rec.aviation.soaring
Brad[_2_]
shock absorber
easy to use
See ya, Dave
ya know, that is a pretty cool looking contraption, but from a
homebuilder point of view, making it out of aluminum tubing, extrusion
and flat sheet is much easier and less labor intensive. might be a bit
heavier, but not much. of course the wing cuff would be composite!
Old July 28th 10, 03:26 PM posted to rec.aviation.soaring
Andy[_10_]
shock absorber
easy to use
See ya, Dave
Looks sleek but you need three hands to put it on the wing. Also, not
that you'd do it all that often but I would not be inclined to tow the
glider nose first with that long trailing arm. It would be
directionally unstable like a weather vane pointing downwind.
9B
Old July 28th 10, 03:32 PM posted to rec.aviation.soaring
Morgans[_2_]
"Andy" wrote
Also, not
I wondered about that, too. I wonder if she put it on backwards?
Old July 28th 10, 03:56 PM posted to rec.aviation.soaring
Brad[_2_]
On Jul 28, 6:32*am, "Morgans" wrote:
"Andy" wrote
*Also, not
*I wondered about that, too. *I wonder if she put it on backwards?
she wasn't blonde...................just sayin'
Brad
Old July 28th 10, 04:02 PM posted to rec.aviation.soaring
Bob
Look again, she put it on the correct way. Maybe towing tail first is
not how Y'all do it?
Old July 28th 10, 04:37 PM posted to rec.aviation.soaring
Bob Kuykendall
Actually, the carbon has some pretty compelling advantages. It is a
lot lighter, so that it is easier to stow, carry, and attach.
I think that carbon sleeve over EPS or EPP rod would indeed do the
trick for the arm. If you were serious about it, you'd have a high-
pressure female mold, and mold the part by inflating a plastic bladder
inside the sleeve material, but the male molded part would be almost
as stiff and easier and cheaper to make for just one or two.
As Dave points out, it can be made springier, so that the goofy steel
spring and shock absorber isn't required. The way it grabs the axle on
only one side of the wheel is a neat trick, but the greater bending
loads makes the axle heavier than if the arm were forked.
As Andy points out, the leading arm might be divergent, but I don't
think that it is actually unstable except at very high speeds and
loads.
Thanks, Bob K.
Duo Discus Wing Wheel -- not Dolly [email protected] Soaring 0 November 1st 07 04:57 AM
Carbon fiber shortage? [email protected] Home Built 3 December 11th 05 08:24 AM
Composite & Carbon Fiber NW_PILOT Home Built 11 September 21st 04 07:21 PM
carbon fiber dutchpilot Home Built 0 June 16th 04 01:20 PM
Carbon fiber vs. antennas [email protected] Owning 2 January 2nd 04 02:40 PM
