Denver ARTCC (ZDV) Code 1201
Old September 22nd 10, 11:38 PM posted to rec.aviation.soaring
Frank Whiteley
Default Denver ARTCC (ZDV) Code 1201
Glider use of 1201 encouraged.
Tow planes use 1200.
Thanks for ping from Elliott Crawford, CFI-G.
Frank Whiteley
SSA State Governor, Colorado
Old September 23rd 10, 04:22 AM posted to rec.aviation.soaring
BTiz
Frank Whiteley
Not all areas are set up to accept 1201 codes just yet. Our local
approach control needs to change a letter of agreement with a jump
school. There local LOA has assigned 1201 to the jump plane, long
before the national discussion for a US wide glider code.
BT
Old September 23rd 10, 09:06 AM posted to rec.aviation.soaring
Bruce Hoult
I would think that a jump plane using the same code as a glider tow
plane would be entirely sensible. Both are climbing higher and more
quickly in a small area than typical GA, and then descending as
quickly as practical.
If you have them both (and people doing aerobatics) on 1201 with
gliders then it can be a code for "rapid and/or uncontrolled altitude
excursions" with people droning from place to place at a relatively
stable altitude on 1200.
Old September 24th 10, 03:57 AM posted to rec.aviation.soaring
BTiz
Not when the jump plane calls TRACON for permission to jump and the
"automatic data block" is attached to the tow plane not on approach
frequency.
1201 & Tow Planes Jamie Shore Soaring 5 September 13th 10 03:35 AM
Transponder squawk code 1201 approved for ZDV Frank Whiteley Soaring 0 June 7th 10 09:00 PM
1201 VFR Glider Code - Approved PHL-ABE-NY Tracon RL Soaring 0 April 13th 10 08:47 PM
Chicago Tracon, Glider Code 1201 Herb Soaring 1 April 7th 10 01:06 AM
FAA: LA ARTCC Outage Blamed On Maintenance A Guy Called Tyketto Piloting 0 September 17th 04 09:38 PM
