Complex Aircraft Question
Old October 14th 03, 03:51 AM
Chris
Default Complex Aircraft Question
I've recently obtained my multi-eingine rating in a seneca can this complex
aircraft time be used toward the FAR requirement of 10 hours of training in
a complex aircraft for a COMMERCIAL SINGLE ENGINE RATING (NOT MULTI). I have
about 11.5 complex between the seneca and an Arrow?
Thanks in Advance
Chris
Old October 14th 03, 02:11 PM
Sylvain
"Chris" wrote in message ...
Thanks in Advance
Chris
I'd like to take a shot at this one :-)
in short, my answer is YES which I justify as follows:
disclaimer: I am not a lawyer, but I am trying to become a CFI and
would like to see if I understand some of the finer points of
interpreting
our beloved 14 CFR scriptures... so here it goes:
I reckon that you are referring to 61.129(a)(3)(ii) which stipulates
the aeronautical experience required for the commercial certificate
for
an airplane single engine (and I would assume that you do not already
hold a commercial certificate in another class of the same category,
i.e., that 61.63(c) does not apply);
....so it reads: ''10 hours of training in an airplane that has a
retractable landing gear, flaps, and a controllable pitch propeller,
or is turbine-powered, or for an applicant seeking a single-engine
seaplane rating, 10 hours of training in a seaplane that has flaps and
a controllable pitch propeller;''
It says explicitely ''in an airplane'' without specifying whether said
airplane is a single engine or not, unlike, for instance, the
requirement
on 61.129(a)(3)(i) which specifies that at least 5 hours of the
required
10 hours of instrument training must be done in a single engine
airplane.
So, I contend that if the FAA had meant for the complex aircraft to
be
a single, they would have said so explicitely.
voila voila.
what do you guys think?
--Sylvain
ps I got my commercial single engine using the 61.63(c), i.e., as an
additional class rating;
Old October 14th 03, 02:13 PM
Sylvain
and I forgot: congratulations on your multi- rating!
--Sylvain
Old October 14th 03, 07:32 PM
Phil Rynn
I agree with Sylvain. I will be getting my SE Commercial one of these days.
While I have ME ATP, I have never flown any SE planes other than C-152/172
and PA-28. Basically, I was going to take the commercial a few months back,
but then moved, changed jobs, etc. The CFI's that I spoke with all agreed
that all I would need is the necessary dual time (6 hours within 60 days
IIRC) and a checkride. So yeah, I believe that the FARs are written the
way they are specifically to be interpreted the way Sylvain has.
Phil
complex
in
have
Thanks in Advance
Chris
Old October 15th 03, 05:49 AM
Sylvain
"Phil Rynn" wrote in message .net...
Phil
another interesting consequence of already having a commercial or better
like yourself in a multi-, is that the aircraft you will be using for the
single engine commercial checkride does not have to be a complex either :-)
(took my commercial ASEL in a Citabria :-)
--Sylvain
Old October 18th 03, 05:40 AM
Phil Rynn
Good point. I had initially planned to get my SE commercial in a C172, and
figured the minimum I would have to do was the 6 hrs of instruction and then
a checkride. Just haven't had the time to do it yet.
Phil
"Sylvain" wrote in message
om...
.net...
days.
C-152/172
back,
agreed
Phil
--Sylvain
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 03:39 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
