Fuel efficient freight planes
Old November 14th 03, 03:25 AM
Jonas Heisenberg
Default Fuel efficient freight planes
Hi all.
Looked around a bit for fuel efficient (big, commercial) airplanes.
The best ones I found were the Tupolev TU-330 and the Antonov AN-70.
They had cruising speeds/fuel consumption of 780-850 km/h and 118-125
g/t-km. Now my question: would lowering the cruising speed to e.g.
300-400 km/h make them more efficient?
Thanks, Jonas
Old November 15th 03, 04:47 AM
Steve McCroskey
Jonas,
At some point you'll reach a point of diminishing returns. As
speed decreases induced drag increases and you need to increase power
to maintain altitude/speed. Most jet aircraft have a maximum cruise
power, long range cruise power and intermediate cruise power setting.
Intermediate gives the best time to burn ratio, but if your prime
concern is fuel savings and extended range, then you could fly at the
LRC setting, which, in some aircraft, could yield up to a 15% increase
in range. The expense, though, is flight time.
P.
(Jonas Heisenberg) wrote in message om...
Hi all.
Thanks, Jonas
Old November 16th 03, 02:21 AM
Jonas Heisenberg
Thanks for your replies.
So as I understand it, these planes are constructed to operate most
economically at ca. 80-90% of their maximum speeds. Has it ever been
tried to build planes that are built specifically for lower speeds and
higher efficiencies (recent - no WWII)?
Jonas
Old November 16th 03, 08:53 AM
Pat Barry
Yes- look at a Twin Otter.
Jonas
Old November 17th 03, 03:24 AM
Jonas Heisenberg
The Twin Otter seems to be slower, though less fuel efficient than the
planes mentioned above. Probably the Air-Ships of the 30 were? Saw a
documentary about someone who went 1200km with a glider in the Andes.
Maybe Motor-gliders would be most efficient?
Jonas
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 01:17 AM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 08:35 AM
