Compression Tests
Old March 22nd 04, 04:51 PM
Doug
Default Compression Tests
Does anyone do an "automotive" type compression test on their aircraft
engine? I think this kind of "dynamic" test might show problems (such
as valves not opening all the way), that a leakdown test would not
(and vice-versa). Anyway my annual is coming up and I want to do it. I
imagine something that screws in and has a long hose to the guage, so
no one has to stand behind the propellor.
Old March 26th 04, 07:20 AM
Pat Barry
You can conduct whatever you like - however your IA will require that a
leak down test be performed since it is prescribed under Part 43.
Old March 27th 04, 12:08 AM
prove it.
TC
Old March 27th 04, 06:29 AM
Jim Weir
Pat Barry
-You can conduct whatever you like - however your IA will require that a
-leak down test be performed since it is prescribed under Part 43.
That happens to be bull****.
http://www.rst-engr.com
Military looks to next round of tests for Osprey Otis Willie Military Aviation 0 September 19th 04 12:01 AM
Compression loss on cylinder when rings line up Truth of fiction? test it Home Built 10 May 11th 04 09:11 PM
Compression Tests Doug Aerobatics 4 March 27th 04 06:29 AM
0200A Higher Compression Cylinders? Boelkowj Home Built 3 December 16th 03 03:25 PM
Not Particularly Impressed with Tuskegee Airmen Propaganda. The Enlightenment Military Aviation 25 July 11th 03 10:01 PM
