rough engine just after power reduction
Old July 25th 03, 04:07 PM
Sydney Hoeltzli
Default rough engine just after power reduction
Last night, on a short hop back to home base after an
instrument lesson (read: extended low power ops),
engine shuddered and ran very rough just after level-off
and power reduction. Run-up and takeoff were normal,
and as usual I leaned like heck for taxi and during
runup. About 80 degrees with blissfully low humidity,
carb ice unlikely esp. in our installation, not very
carb ice prone.
Ground ran with brutal leaning afterwards and checked
all chts/egts on both, r and l mag. r mag ran rougher,
with higher EGT on #4 cyl.
Suggestions? Going out to clean plugs and make sure
all 4 cyl have compression this afternoon, what else
to check? I'm hoping for a badly fouled plug, but
would that produce high EGT on 1 mag?
BTW I envy the chap in the other thread who posted about
"continuing as normal as possible" because an engine w/
a blown valve will continue to make normal power for
a long time. Personally when my engine is running rough
I'm not capable of such savoire-faire, I operate on the
assumption that I really don't know what's up and the
b**ch may quit on me any second. I want as much energy
as I can bank until I have the runway made.
Cheers,
Sydney
Old July 25th 03, 04:46 PM
H. Adam Stevens
"Sydney Hoeltzli" wrote in message
carb ice prone.
Cheers,
Sydney
Hi Sydney
I've had two rough engine scenarios in flight.
Once in '69 in a Cardinal and it just cleared up with leaning.
The other time in a Skyhawk; Dropped an exhaust valve and I landed at the
nearest airport.
Both cases carbureted Lycoming 4's.
Never had ice that I noticed.
H.
N502TB
Oh yes, my Baron is still sitting there.
Seven weeks.
Old July 25th 03, 08:09 PM
Ryan Ferguson
Wow, this is the first time I've heard an actual first-hand account of
the engine running rough after the initial power reduction.
Good job handling it, Sydney.
Fouled spark plug, faulty spark plug, bad lead, bad distributor... all
possibilities.
Was there any drop in CHT on cyl. #4? If so, it could be a burned
exhaust valve.
Let's hope it wasn't anything expensive.
-Ryan
CFII-A/MEI/CFI-H
Old July 25th 03, 08:25 PM
Ben Jackson
I'm not an expert, but I understand you can get weird effects if the
combustion is still going on during the exhaust cycle. I thought that
was usually due to a leaking exhaust valve, though.
Ben Jackson
http://www.ben.com/
Old July 26th 03, 01:17 AM
John Galban
Sydney Hoeltzli wrote in message ...
snip
Puzzling! It sounds like a bad or fouled plug, but the EGT doesn't
make sense. If you were running on both mags, a bad plug would show
up as a higher EGT on that cylinder. If you switched to the rough
running mag, the EGT for the bad plug should drop. Running on a
single (good) plug causes the EGT to rise since the fuel air mixture
doesn't burn as quickly and is still burning when ejected into the
exhaust. If you're running on a single plug that is firing
intermittently, I'd expect the overall EGT to be lower, since there
are (cold) unburned charges exiting the cylinder.
Could the high EGT reading be coming from unburned charges being
ignited in the exhaust stack by subsequent burning charges?
Cheers,
Sydney
Old July 26th 03, 04:04 AM
G.R. Patterson III
It could do that. High EGTs can be produced by a slow fuel burn in that
cylinder, and this can be produced by fouled plugs.
Make sure you check the wiring harness too. Last time I had this sort of
problem, one plug was fouled *because* the other one wasn't firing and
she was running too rich on that cylinder. The other plug wasn't firing
because the plug wire had quit conducting electrons.
George Patterson
The optimist feels that we live in the best of all possible worlds. The
pessimist is afraid that he's correct.
James Branch Cavel
Old July 26th 03, 04:50 AM
Sydney Hoeltzli
And it was higher, a bit, on a cylinder which usually isn't
the hottest...
'swhat I would have thought too.
Well, there was a lot of lead fouling in all the bottom plugs
(which were cleaned recently -- ugh!). But nothing that looked
as though it should have put one plug out of commission. Unless
I burnt it off with ground running, I'm suspicious that this
isn't the end of the problem.
Just pulling through the prop, it's clear that #4 cylinder
(the one w/ the high EGT) doesn't have as much compression
as the others. Still got compression though. Dunno how
quantitative. Pulled the rocker box cover, no sign of soot
in the oil (the poor man's "exhaust valve going bad" warning
system). #4 happens to be our only remaining NuChrome cylinder
and had lower compression than I'd like last annual (no leakage
past the valve though, and the wobble check was good)
How does one check the ignition wires for proper function,
and if one plug isn't producing spark as George suggested,
would it be fouled?
Methinks a compression check is in our future. Meworries about
another sort of check.
Meworries more about not tracking down the problem...of course
some people would say I worry too much about 1 minute of rough
running.
Cheers,
Sydney
Old July 26th 03, 09:24 PM
smf
I have Glasair II with I-O360. When training and running low power for
extended periods I get a little roughness. If I run it harder then I don't
get the roughness. It may pop on final or while taxing, my mech said it is
because the plugs get "loaded up". Meaning a little fouling. When my
instructor wants me to stay at 90kts my power settings are very low and the
engine oil heats up to a little over 200F. Other wise it runs 190-195. This
is because airflow and nose high attitude.
Steve
Old July 26th 03, 10:12 PM
Sydney Hoeltzli
George,
How would you check the wiring harness?
As of today, Tigger was running like a Tiger and purring like
a kitten.
EGTs were lower on ground run too.
So we'll hope it was bad plugs, but my "we haven't gotten to
the bottom of this" warning is still beeping in the back of my
head.
Cheers,
Sydney
Old July 26th 03, 10:40 PM
G.R. Patterson III
Unfortunately, I don't know. My A&P did that when I had my problem.
George Patterson
James Branch Cavel
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 10:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 07:46 PM
First Emergency (Long Post) [email protected] Owning 14 July 23rd 03 03:46 AM
