Propellor pitch ...
Old July 29th 03, 02:57 AM
Bob Noel
Default Propellor pitch ...
In article , "N3722A"
I have a Sensenich 72CK-0-56 prop on my plane - is the "56" the pitch on
prop?
yes.
Also, can one have a prop "re pitched" so to speak to give more of a
climb
performance than cruise? It seems I once read (correct me if I am wrong)
that this number (56) is the pitch and if one can have a prop reworked to
a
lower pitch (like 52) one can get a better climb performance.
I suggest you contact Sensenich about the limits of re-pitching.
I would think that changing the prop pitch would require either
an STC or field approval (if not already covered by the original
type certificate). For example, the STC to install a 160hp engine
in my cherokee 140 also allowed either the original 58 pitch
or a 60 pitch prop.
Good luck.
Bob Noel
Old July 29th 03, 05:25 AM
Tony Roberts
Also, can one have a prop "re pitched" so to speak to give more of a climb
I just discussed this with my tech last week. He told me that I can have
the prop repitched for climb on my 172H for around C$350.00.
Tony Roberts (tonyroberts@ remove shaw.ca)
PP-ASEL
VFR-OTT - Night
Cessna 172 C-GICE
Old July 29th 03, 05:30 AM
On Mon, 28 Jul 2003 16:05:14 -0700, "N3722A" wrote:
I have a Sensenich 72CK-0-56 prop on my plane - is the "56" the pitch on the
prop?
Yup.
that this number (56) is the pitch and if one can have a prop reworked to a
sig snip
http://www2.sensenich.com/direct/propdir.htm
Has a lot of useful information. If a pitch range is "approved" for
your particular aircraft (there are quite a few that have
standard/climb/cruise listed) you still need to ensure that the
certified static rpm range is still maintained.
Any prop shop that re-works/overhauls/sells Sensenich props should be
able to give the straight scoop on what is allowable for your
aircraft.
TC
