plastic or metal fenders on the trailer?
Old December 19th 10, 02:55 AM posted to rec.aviation.soaring
chris
Default plastic or metal fenders on the trailer?
Lost another plastic fender to another blown tire [insert lecture on
changing tires at 6yrs]. I can buy metal fenders locally for like
$18. Or somewhere I need to find a source for the plastic ones for my
old 1979 Komet trailer.
Who sells the plastic ones? (who supports Komets in the US?)
Is there any downside to switching to metal fenders over the plastic
ones?
Was wondering if there is an advantage to the frangible / tear away
quality of the plastic ones or metal should be fine.
Hey it is cold and rainy, good time for a trailer discussion and I
need an answer this week anyway.
Chris
Atlanta, GA, US
Old December 19th 10, 03:55 AM posted to rec.aviation.soaring
Etrailer works for me, I doubt that the plastic fenders I bought there
will last much longer than the tires (ST rated tires have special
compound, should last 8-10 years)
I got plastic fenders because they were lighter and rustproof. If I
were to buy them again, i would put a cover over both fender and tire.
aerodyne
Old December 19th 10, 06:01 AM posted to rec.aviation.soaring
glidergeek
changing tires at 6yrs]. *I can buy metal fenders locally for like
$18. *Or somewhere I need to find a source for the plastic ones for my
ones?
Chris
Atlanta, GA, US
Buy steel fenders @ a trailer supply place, take them & have them
powder coated bolt them on and you can sit on them and change your
socks and shoes. Can't do that with plastic.
Old December 19th 10, 06:11 AM posted to rec.aviation.soaring
ones?
Chris
Atlanta, GA, US
socks and shoes. Can't do that with plastic.- Hide quoted text -
- Show quoted text -
Not true, I do that with my plastic fender, they have built in steps
(3)n I can put my full weight on all portions, even stand securely on
the top of the fender to access the trailer roof, Difficult to do
that with a smooth steel fender without traction grips on dedicated
step areas.
I powder coated various parts of the frame and fender supports, IMO
powder coating will not last on the thin steel of a fender. Powder
coating will add to the cost and make it as expensive at a plastic
one. Of course, YMMV
aerodyne
Old December 19th 10, 07:05 AM posted to rec.aviation.soaring
Matt Herron Jr.
ones?
Chris
Atlanta, GA, US
the top of the fender to access the trailer roof, *Difficult to do
step areas.
powder coating will not last on the thin steel of a fender. *Powder
one. *Of course, YMMV
aerodyne
I have steel fenders on my Cobra trailer. A blowout took the back
half of the fender and folded it double inside itself. So I am not
sure steel is any more durable than plastic. Although I was able to
take it off, pound it back into shape, and re-paint it. Not quite so
purdy anymore...
Matt
Old December 19th 10, 04:56 PM posted to rec.aviation.soaring
Chip Bearden[_2_]
I have a blue plastic Cobra fender (right side) left over from when
its mate was taken out by a piece of tire tread lying on the freeway
the first year I owned the trailer (1982). I bought galvanized steel
fenders from Northern Hydraulics (now Northern Tool). They were nearly
a bolt on (had to redrill one or two holes) and would still look good
today except for:
1. My trailer sits outside leaning at a slight angle. The fender on
the low side catches the runoff from the roof and has a rust streak as
a result. Unsightly, not structural.
2. Two years ago I blew a tire dramatically and, as another poster
similarly reported, it bent the rear few inches back in on itself. I
banged it out and may even one day smooth it off and paint it, but
it's servicable.
If I had it to do over again: metal. No question about it.
Chip Bearden
ASW 24 "JB"
USA
Old December 19th 10, 07:02 PM posted to rec.aviation.soaring
sisu1a
I have steel fenders on my Cobra trailer. *A blowout took the back
half of the fender and folded it double inside itself. *So I am not
sure steel is any more durable than plastic. *
Really? Imagine what your fiberglass/aluminum trailer would have
looked like if that steel fender hadn't absorbed like 90% of the
energy of the blowout. In addition to a mangled trailer, your glider
would have probably been damaged inside as well like this recent
victim of plastic fenders:
http://groups.google.com/group/rec.a...9415b95aad7d6#
Another good reason for metal fenders is that they provide a little
more protection from other cars/trailers as well...
-Paul
Old December 19th 10, 10:04 PM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
-Paul
Another blown tire? That's your problem. Upgrade to proper heavy walled trailer tires. Tires should never blow.
Old December 19th 10, 10:16 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
I've known a lot of people (including me) that have lost a tire on a
COBRA trailer, with no damage to anything but the fender. The 1984 Komet
trailer might be a more fragile animal.
How much you use the trailer, and how much a problem rust is, may be the
way to choose. I fought chronic rust on my steel race car trailer
fenders (inside the fender and the front of the fender - mostly rock
chips), but rust is not an issue with my Cobra's plastic fenders.
Northern Tool also has aluminum fenders - a good compromise, perhaps. Or
find someone that will sell you stainless steel!
For the last few years, I've had a tire pressure monitoring system on
the tow vehicle that includes the trailer tires, hoping to avoid the
tire failure in the first place. Looking the tires every time I gas up
helps, too. If the tread is beginning to separate, this will likely find
it before the tire pressure is affected.
email me)
Old December 20th 10, 12:29 AM posted to rec.aviation.soaring
Andy[_1_]
In some cases, perhaps not all, I think the tread separates completely
and the tire continues to run inflated until the carcass fails. I
think that's what happened when my Cobra tire failed. There was no
damage as would have been caused by a flailing tread and only about 3
inches of the rear of the fender cleanly rubbed away along with half
the mud flap. I had a flailing tread failure on the Minden trailer and
it bent the hell out of the steel fender and the rear support bar.
Andy
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 03:11 AM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 11:24 PM
boat fenders on winch launch strops Kenneth Leslie Fixter Soaring 0 July 21st 05 11:01 PM
Metal Trailer for sale Nolaminar Soaring 0 March 1st 04 12:15 AM
Enclose metal trailer...for sale Nolaminar Soaring 0 October 17th 03 05:33 PM
