ADF antenna
Old August 13th 03, 07:24 PM
Dan Luke
Default ADF antenna
What is the proper length?
Since my old one departed in flight, I have nothing to measure the new one
against.
Dan
C172RG at BFM
Old August 14th 03, 12:44 AM
mikem
On Wed, 13 Aug 2003 12:24:41 -0500, "Dan Luke"
against.
Depends on the ADF. I have an installation manual for the Cessna ARC
R546? which shows the correct length of the sense antenna from top of
wing to the insulator. You can by a new stainless steel sense wire kit
from Chief and others.
MikeM
Old August 14th 03, 02:29 AM
Jim Weir
It is pretty loose. The AGC makes up for a multitude of length errors. I
generally start out at 72" and go from there. Always worked for me.
mikem
-On Wed, 13 Aug 2003 12:24:41 -0500, "Dan Luke"
-c172rgATbellsouthDOTnet wrote:
-What is the proper length?
-Since my old one departed in flight, I have nothing to measure the new one
-against.
-Depends on the ADF. I have an installation manual for the Cessna ARC
-R546? which shows the correct length of the sense antenna from top of
-wing to the insulator. You can by a new stainless steel sense wire kit
-from Chief and others.
-MikeM
http://www.rst-engr.com
Old August 14th 03, 03:48 PM
Ron Natalie
"Dan Luke" wrote in message ...
Why does it depend on the ADF? Wouldn't it be some fraction of an
average wavelength for NDB frequencies?
It's a very tiny fraction of teh NDB frequency wavelength, which is over
200 meters. The radio has to have some internal matching for the
much shortened length.
LORAN antenna difference? JFLEISC Home Built 6 December 24th 04 11:10 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 02:10 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 06:34 PM
