Using an Android Phone as a GPS logger - ie the really poor gliderpilots GPS!!!!!
Old January 20th 11, 08:47 PM posted to rec.aviation.soaring
kiwi ross
Default Using an Android Phone as a GPS logger - ie the really poor gliderpilots GPS!!!!!
Hi Everyone,
Logged my 1st OLC flight yesterday from my Android phone which I
thought was quite cool ... havent in the past ever got around to
having a personal GPS logger or PDA, just used the club ones including
the hassle of downloading from a Cambridge with a RS232 serial port ..
yuk especially when your old laptop dies.....
For anyone interested just downloaded XCSoar (which seems to have a
problem at the moment with the logging component but otherwise
generally works okay - good work guys getting it onto android) and the
Hang gliding software 'Gaggle' from the Android Market. Gaggle created
a good trace which was savable in IGC format and simply emailed the
file to myself and uploaded into OLC....
To get better phone battery performance attached a $10 solar battery
pack which had 2 Lithium AA batteries attached by USB - mini USB ...
that gave a 4.5 hr GPS and moving map battery life on a previous
flight which seems to suffice.
Phone was pretty useless in full sunlight for seeing too much but all
up was pretty pleased with the result using standard phone ...
Anyrate maybe a simple solution that allows anyone with a cheap
Android phone to put a flight in OLC without any dedicated equipment
apart from their phone..... doesn't compare with a full glider GPS
solution but maybe a way to get more student pilots logging flights on
OLC.... thoughts anyone ..... anyone dug up other options in this
area ....
cheers
Ross
http://www.onlinecontest.org/olc-2.0...t=olc&pi=38463
Old January 21st 11, 01:06 AM posted to rec.aviation.soaring
Mike the Strike
Default Using an Android Phone as a GPS logger - ie the really poorglider pilots GPS!!!!!
On Jan 20, 12:47*pm, kiwi ross wrote:
Hi Everyone,
area ....
cheers
Ross
http://www.onlinecontest.org/olc-2.0....html?sp=2011&....
....and Google just announced they are going to support a barometer
function, which will likely be built in to newer phone models. It
shouldn't be too difficult to add pressure altitude logging when this
becomes available. I see no reason why this shouldn't be acceptable
for at least badge and OLC flights.
Old January 21st 11, 01:46 AM posted to rec.aviation.soaring
GK[_2_]
On Jan 20, 2:47*pm, kiwi ross wrote:
Hi Everyone,
area ....
cheers
Ross
- At one point of your flight logged as low as -325 meters below the
the take off point...
Old January 21st 11, 07:18 AM posted to rec.aviation.soaring
Max Kellermann
Default Using an Android Phone as a GPS logger - ie the really poor glider pilots GPS!!!!!
I can't find your bug report. Bugs don't get fixed unless somebody
reports it to our bug database.
http://www.xcsoar.org/trac/newticket
Btw. XCSoar is OLC approved, even when used without pressure altitude.
Max
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT Naval Aviation 4 April 3rd 04 04:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT General Aviation 4 April 3rd 04 04:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT Owning 4 April 3rd 04 04:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ... JohnMcGrew Piloting 0 March 30th 04 01:52 PM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ____ WJloELC0 MLenoch Piloting 3 March 30th 04 06:17 AM
