Cad drawing for ASW27 or ASG29 instrument panel
Old January 20th 11, 11:09 PM posted to rec.aviation.soaring
Larry Goddard
Default Cad drawing for ASW27 or ASG29 instrument panel
Trying to help a friend with instrument layout for a new panel. Anyone
have a cad drawing of one of these?
Larry
Zero One
Old January 20th 11, 11:22 PM posted to rec.aviation.soaring
KevinFinke
You can get a very high quality PDF drawing from the AS website.
Should then be possible to bring that into a CAD program and convert
it into a CAD dataset.
http://www.alexander-schleicher.de/s...20ib%20001.pdf
-Kevin
Old January 20th 11, 11:28 PM posted to rec.aviation.soaring
Brad[_2_]
-Kevin
can't a PDF file be opened in a vector/spline based application like
Adobe Illustrator? if so, it should be relatively easy to get what you
need, sizing the view space and the printing window would take some
tiling tho.
Brad
Old January 20th 11, 11:49 PM posted to rec.aviation.soaring
Larry Goddard
Thanks!!!!
Should have poked around further on the website before giving up....
Larry
"KevinFinke" wrote in message
-Kevin
Old January 21st 11, 02:55 AM
OregonGliderPilot OregonGliderPilot is offline
Junior Member
First recorded activity by AviationBanter: Sep 2009
[quote=Larry Goddard;760470]Thanks!!!!
Larry
I have a .dwg of my ASG29 large panel if you are still looking.
MG
Old July 22nd 14, 03:54 PM posted to rec.aviation.soaring
Nik[_2_]
Could you please share that .dwg file?
Thanks in advance, Nik
On Friday, 21 January 2011 02:55:57 UTC+1, OregonGliderPilot wrote:
Larry Goddard;760470 Wrote:
Thanks!!!!
Larry
MG
OregonGliderPilot
Old July 22nd 14, 05:19 PM posted to rec.aviation.soaring
Bob Kuykendall
Here's a DWG version of that panel. Double check it before you put much faith in it:
http://www.hpaircraft.com/misc/ASG29_Panel.zip
Thanks, Bob K.
Old July 23rd 14, 02:40 PM posted to rec.aviation.soaring
Nik[_2_]
Thanks alot Bob!
Kinda regards, Nik
Thanks, Bob K.
Old July 24th 14, 02:47 AM posted to rec.aviation.soaring
That works too. You can laser cut a template with the screw holes and center holes only and go the hole saw route. Only works for the round instruments. :-)
I tried it both ways and even with a drill press to hold the hole saw it wandered off center on me by about 0.05". I'm sure with practice I could get better but the hole saw was also slightly over size to the instruments and I literally needed to be on target to 0.002" because I had several instruments separated by the thickness of a sheet of paper or two.
CNC also works but takes more effort to get the tool offsets and cutter path programmed.
9B
Old July 24th 14, 02:59 AM posted to rec.aviation.soaring
Bill D
9B
The last time I did a project like this I sent the CAD file to a plastic shop who used it to laser cut a 1/8" plexiglass panel complete with mounting holes and instrument holes. IIRC the bill was $35. That let me test all the instrument installations and fittings with a panel I could see through which made detecting interference easy. Then I sent the file to a metal shop who laser cut the panel itself. That part cost $70. Everything fit perfectly.
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 07:50 PM
CAD drawing for DG instrument panel... Marc Ramsey Soaring 5 April 7th 06 08:12 AM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 03:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 03:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 05:37 AM
