I have an old whiz wheel that is apparently used to calculate height
needed to cover a specified distance. I got it with my Libelle 201B. Was just looking at it and trying to figure it out. It has a semicircular rotating part on the front with Height Needed across the top and a speed scale across the bottom (flat side). On the fixed card, the outer scale is Nautical Miles to Go and there is a wind component graph at the bottom left and upper right. It looks like I put my speed to fly over the wind component and then read altitude required under the desired distance. Does anyone know if that is correct? Also, I think it's missing a piece on the back. The back of the whiz wheel is labeled JSW Wind Component Resolver. The brass hub is there, but there's not any moving part, which I suspect is required. It says made in England, Copyright 1986 JS Williamson. Can anyone give me more information about this little device? |
Think there was just one moving part on the front, operating as you
assumed. It's also been called a Dial-A-Prayer Wheel. I probably still have one somewhere, along with a similar dusty old slide rule for SCUBA diving. ....Or did it get given away with the barograph, foil and camphor? Jim |
it should have the simple instruction written right on it.......most did
simple to set the datum mark to the distance to go and read the altitude needed (on the squiggled line for the different winds) and/or set the datum line to the altitude you have and read the distance you can go before striking the earth surface...pretty much works like an E6B. tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Dave White" wrote in message ... I have an old whiz wheel that is apparently used to calculate height needed to cover a specified distance. I got it with my Libelle 201B. Was just looking at it and trying to figure it out. It has a semicircular rotating part on the front with Height Needed across the top and a speed scale across the bottom (flat side). On the fixed card, the outer scale is Nautical Miles to Go and there is a wind component graph at the bottom left and upper right. It looks like I put my speed to fly over the wind component and then read altitude required under the desired distance. Does anyone know if that is correct? Also, I think it's missing a piece on the back. The back of the whiz wheel is labeled JSW Wind Component Resolver. The brass hub is there, but there's not any moving part, which I suspect is required. It says made in England, Copyright 1986 JS Williamson. Can anyone give me more information about this little device? __________ Information from ESET NOD32 Antivirus, version of virus signature database 5837 (20110201) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5837 (20110201) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
| Thread Tools | |
| Display Modes | |
| density altitude calculator and wind calculator on web site and asGoogle gadget | Howie | Piloting | 3 | August 6th 07 12:52 AM |
| density altitude calculator and wind calculator on web site and asGoogle gadget | virtuPIC[_2_] | General Aviation | 0 | August 4th 07 06:55 PM |
| VFR xcountry calculator/log (NEW!!!) | Cecilia Lang | Piloting | 0 | December 26th 05 11:45 AM |
| Calculator | Phoebus_810 | Soaring | 0 | January 8th 05 05:36 PM |
| JSW Glide Calculator | snaproll59 | Soaring | 5 | November 7th 04 05:01 PM |
