Magneto Failure
Old October 17th 03, 08:12 PM
Chick Urick
Default Magneto Failure
Has anyone experienced both "P" leads in a D2000 shorting out against
the back of the case? It appears this may have happened in a C172
(1979) as there are arc marks at the connectors. Looks like a gasket
should have been install but none is there? Any comments appreciated.
Old October 18th 03, 02:01 AM
Chick Urick wrote in message . ..
You've got me swinging.
The "P" leads on D2000 screw into the back side of the capacitors last
time I checked.
It is not uncommon for the wires from the capacitors to the points
getting pinched in between the case halves, that's typically an
installation/assembly issue.
The only "gasket" that I'm familiar with goes between the halves, and
is only used on pressurised installs.
TC
Ramifications of Cherokee Trim Jackcrew Failure Bob Chilcoat Home Built 23 June 9th 04 03:48 AM
"System Failure Is Blamed In U.S. Downing Of British Jet" Mike Military Aviation 20 May 21st 04 07:39 PM
Alternator failure modes (long) mikem Owning 1 September 21st 03 08:47 PM
In Flight Failure Charles Talleyrand Military Aviation 1 August 4th 03 06:25 AM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 04:01 AM
