Brief review of Android XCSoar on the Streak 5 and LK8000 on the MIO 400
Old March 31st 11, 09:15 PM posted to rec.aviation.soaring
Mike[_8_]
Default Brief review of Android XCSoar on the Streak 5 and LK8000 on the MIO 400
Just received a Streak 5, updated to Froyo and installed XCSoar for
Android, and thought I would compare it to the MIO 400 with LK8000
that I used last year and give a quick review.
First of all, if you purchase a Streak 5 on Ebay, expect to pay about
$300-$400.00. If it is a used Streak like I bought you may have to
update from 1.6 to Froyo. It is not difficult, but there is always a
chance you could brick the device. I could not get the 1.6 version of
the Streak to find XCSoar on Android Market and could not install
XCSoar, or any other program, that was not downloaded from the market.
If there is a way, I could not find it. The Froyo update fixed that.
The used MIO cost me $40.00 from Amazon and I had to do a fairly
simple hack to install LK8000. There is also a slight chance you could
brick the MIO. All info, step by step, is on the LK8000 forum, and
help is available if you get a baffled.
Both devices were like new, although the MIO battery was replaced for
$15.00.
Which system was better?
It was easier to load XCSoar from the market on to the Streak, than it
was to load LK8000 on to the MIO.
The screen on the Streak 5 is 5" measured diagonally, while the MIO is
about 4.25". The moving map section of both screens are about 4".
The Streak 5 is better in direct sunlight at all angles. Although
there is a slight amount of glass glare, it is not a problem. The MIO
is more effected by glare than the Streak, and at times is next to
impossible to see, but a slight angle change solves the problem.
There are other considerations.
If you are wearing polarized sunglasses, things change, and the MIO in
landscape mode improves, being quite good, while the Streak's screen
becomes black. When the Streak is viewed in portrait mode, it is again
very good. The MIO's screen in portrait mode, becomes as poor as the
Streak's in landscape.
The MIO 400 is a great deal, especially if you are wearing polarized
glasses. If you are not wearing polarized glasses, the Streak is
quite a bit better, and in my opinion, worth the extra money.
Old March 31st 11, 10:29 PM posted to rec.aviation.soaring
Max Kellermann
Even though you compared just the two hardware products, you mentioned
explicitly that you tried LK8000 on the MIO. I would like to mention
that XCSoar can run on the MIO, too. The installation procedure is
the same.
I could not get the 1.6 version of the Streak to find XCSoar on
Android Market and could not install XCSoar
Several people have reported that problem with old Android versions.
So far, I could not check this, because all my Android test devices
have Android 2.x, and XCSoar runs just fine in the 1.6 emulator.
According to the Market statistics, 4.4% of all XCSoar/Android users
still have Android 1.6.
Max
Old April 1st 11, 06:17 AM posted to rec.aviation.soaring
Mike[_8_]
Default Brief review of Android XCSoar on the Streak 5 and LK8000 on theMIO 400
explicitly that you tried LK8000 on the MIO. *I would like to mention
that XCSoar can run on the MIO, too. *The installation procedure is
the same.
Max
Today I tested the Bluetooth connectivity between the Streak and LX
Nano. Appears to work fine with the exception of task declaration.
Using a Win CE device the declaration to the Nano is possible through
SeeYou "ConnectMe" but I know of no way using an android base device.
I wish LX would make their output data public, so their products would
be more usable with other soaring programs.
Old April 1st 11, 08:07 AM posted to rec.aviation.soaring
Max Kellermann
XCSoar 6.1 supports task declaration to LX Nano, but it's not released
yet. You can get a preview on the Android Market:
https://market.android.com/details?i...xcsoar.testing
Please give feedback if it works for you. Rob Dunning tested from
Windows Mobile to his LX Nano, and I tested from my Dell Streak to a
Colibri, but never from Android to Nano.
Max
Old April 1st 11, 12:13 PM posted to rec.aviation.soaring
PCool
LK8000 v2.2 will be distributed on april 15th. It supports LX Nano and LX Colibri declaration, it has been tested a lot in the past months.
So we don't need ConnectMe. LX has kindly given out their specifications, and there are no more problems.
"Mike" ha scritto nel messaggio ...
Old April 1st 11, 12:48 PM posted to rec.aviation.soaring
mike
So we don't need ConnectMe. *LX has kindly given out their specifications, and there are no more problems.
* "Mike" ha scritto nel ...
* On Mar 31, 2:29 pm, Max Kellermann wrote:
* Mike wrote:
* Today I tested the Bluetooth connectivity between the Streak and LX
* Nano. *Appears to work fine with the exception of task declaration.
* Using a Win CE device the declaration to the Nano is possible through
* SeeYou *"ConnectMe" but I know of no way using an android base device.
* I wish LX would make their output data public, so their products would
* be more usable with other soaring programs.
Great news concerning LX loggers and task declarations using both
XCSoar and LK8000! Thanks to both teams and to LX.
Old April 1st 11, 09:04 PM posted to rec.aviation.soaring
Mike[_8_]
SeeYou *"ConnectMe" but I know of no way using an android base device..
yet. *You can get a preview on the Android Market:
*https://market.android.com/details?i...xcsoar.testing
Please give feedback if it works for you. *Rob Dunning tested from
Max
Max,
Task declaration works perfectly between the Nano and the Streak.
Triple checked it, no problems.
How stable is the 6.1 test version?
Thank you
Old April 1st 11, 11:22 PM posted to rec.aviation.soaring
Max Kellermann
Thanks, I'm very happy to read that!
Several people have given very positive feedback about 6.1. My
flights with it have been without any complications so far. But
still, you should keep the stable version 6.0.8 installed, just in
case you happen to discover the first severe bug. It's officially
"experimental" at this point.
Max
XCSoar for Android Max Kellermann Soaring 1 April 21st 11 07:39 PM
XCSoar for Android Sean Fidler Soaring 6 March 21st 11 06:50 PM
Short review of the Dell Streak with XCSoar Max Kellermann Soaring 6 February 9th 11 05:22 PM
Streak Shadow david H Home Built 0 December 27th 03 11:43 PM
Streak Shadow david H Home Built 0 December 26th 03 11:22 PM
