Alternator type terminal
Old December 10th 03, 07:47 PM
gix
Default Alternator type terminal
Hi,
I 'm an italian student(then excuse for my english)and i've a problem with
my alternator(120 ampere installed on a Lycoming 360);my problem is the
broken of the wire on the terminal of my alternator,the terminal is intact
but the wire result as cut.
The reason for me is the high vibraction in the zone of connection of the
terminal on the alternator and I don't know if the broken owe by the
rigidity of the wire(the size is for the positive 4 AWG and negative 6
AWG,the type of the wire is Raychem for aereonautical application)or by the
wrong crimp.
I wont ask at you that type of the terminal is indicated use in this case?(I
utilize a Amp PIDG terminal form square);exist other possibily cause?
Thank you in advance
Old December 11th 03, 04:35 AM
On Wed, 10 Dec 2003 18:47:05 GMT, "gix" wrote:
Hi,
wrong crimp.
I am positive that your English is better than my Italian.
The main reason for the wire breaking would either be the wire
routing, or possibly a bad crimp.
The wire should be routed with some slack, and should be mounted so it
can flex/bend somewhere away from the terminal end when the engine is
running.
The wrong crimping tool can also cause problems.
The proper wire and stud/bolt hole size AMP terminal should work fine.
Regards;
TC
Old December 11th 03, 05:07 AM
First I would try to get rid of the vibration. Find someone with a
helicopter balancer. You might try replacing the stiff wire with
flexible silicone jacket welding cable of the same size since this
will take much more flex before it breaks.
A small loop at the terminal will tend to distribute the flex over a
larger length and help stop the breaking where the flex is
concentrated.
Crimp terminals are better than solder in high vibration enviroments.
Hi,
wrong crimp.
Old December 11th 03, 06:14 PM
gix
Tanks very much for all information
Luigi
"gix" ha scritto nel messaggio
Hi,
wrong crimp.
case?(I
Old December 11th 03, 06:16 PM
gix
Hi,
thanks very much for your information,i've appreciate your interest,but i
need of another information:
You talk to sobstitutewire with flexible silicone jacket welding cable but
i don't know this type of wire,be able you to give me factory link or other
information for this wire?
Is this wire usable on the aircraft of general aviation?(spec. militar
standard).
Luigi
Hi,
wrong crimp.
case?(I
IFR Terminal Procedures Tool Todd Neidinger Instrument Flight Rules 12 February 4th 05 02:46 AM
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. Scott Ferrin Military Aviation 29 August 31st 04 05:20 AM
Anyone have experience with InterAv alternator flyer Home Built 6 October 19th 03 04:24 AM
Terminal velocity of bombs? BackToNormal Military Aviation 32 September 24th 03 05:41 AM
