Removing a scratch from a canopy.
Old May 16th 11, 05:27 AM posted to rec.aviation.soaring
Sean Fidler
Default Removing a scratch from a canopy.
Any suggestions or idea's?
Thanks.
Sean
Old May 16th 11, 10:26 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Quote:
Thanks.
Sean
There was a video on Soaring Cafe recently about that very problem with a method to do so.
Walt
Old May 16th 11, 02:34 PM posted to rec.aviation.soaring
Thanks.
Sean
Wings and Wheels has a restoration kit that has the stuff you are
likely to need to polish out.
If it is deeper, precede with fine grades of good quality sand paper,
followed by polishing steps. We use the
finest grade that will remove the scratch in a "reasonable" time, then
progressively finer. 600, 1000, 1200, 1500, 2000, 2500,
then restoration kit seems to work. The finer you can start, the less
you have to do with following grits.
LOTS of water and clean off all residue before next step.
Good Luck
UH
Old May 16th 11, 04:19 PM posted to rec.aviation.soaring
150flivver
Thanks.
Sean
Good Luck
UH
http://www.aircraftspruce.com/catalo...cromeshstd.php
Old May 16th 11, 05:25 PM posted to rec.aviation.soaring
mike
Thanks.
Sean
Sean,
Good advice by UH, but be careful when you remove a deep scratch, as
it can cause an optical distortion when you create a slight depression
in the plexi surface.
Old May 16th 11, 07:07 PM posted to rec.aviation.soaring
jsbrake[_2_]
EAA video on how to do it.
http://www.eaavideo.org/video.aspx?v=665778628001
Old May 17th 11, 07:33 AM posted to rec.aviation.soaring
Paul Besing
Thanks.
Sean
Get a kit called "Micromesh" it has the progressive sandpapers up to
6000 grit I think. Comes with sanding foam and a compound as well.
Aircraft Spruce has it .
Paul Besing
Removing tape residue from canopy BravoNiner Soaring 15 March 23rd 09 08:23 AM
Scratch Remover B. Jensen Home Built 9 August 10th 05 04:48 PM
Scratch Remover B. Jensen Owning 12 August 10th 05 04:48 PM
Removing paint from canopy Jason Restoration 4 November 12th 03 10:22 PM
windscreen pollish/scratch remover centurion_of_evil Rotorcraft 4 October 3rd 03 07:49 AM
