autogas to 100ll
Old January 26th 04, 05:54 PM
Ron Natalie
"Tony Woolner" wrote in message ...
I am looking at a plane that runs on autogas. I can't use autogas at my
airport. Can you convert a plane back to just flying on 100 ll. He says
he flys it on 100 ll also.
There's no conversion to be done. The autogas STC's allow you to
run either autogas or the appropriate grade aviation fuels. The only
problem was the added lead in 100LL (which is "low lead" only compared
to the old 100/130 fuel it replaced, it's got four times the lead 80/87 had).
Of course, you had the lead problem running 100LL before applying the
STC.
With little exception, the STC is just paperwork. It indicates the STC
holder has determined that the auto fuel is of sufficient octane and that
the fuel system is not susceptible to problems like vapor lock with the
auto fuel.
Old January 26th 04, 06:03 PM
Newps
airport.
Why not?
There's no conversion necessary, you can use either/both at any time.
Old January 26th 04, 06:19 PM
Jim Weir
Why not? If it is because the airport authority or the airport manager forbids
it, you'd best be at a completely private airstrip or one that doesn't have a
dime of Federal or State money in it.
Tony Woolner
-I am looking at a plane that runs on autogas. I can't use autogas at my
-airport.
http://www.rst-engr.com
Old January 26th 04, 07:37 PM
Jim Weir
Read it again, Gene. That's what I was telling him. If there is a dime of Fed
or State money in that airport, he CANNOT be prohibited from fueling his own
aircraft.
Gene Kearns
-On Mon, 26 Jan 2004 09:19:11 -0800, Jim Weir wrote:
-Why not? If it is because the airport authority or the airport manager
forbids
-it, you'd best be at a completely private airstrip or one that doesn't have a
-dime of Federal or State money in it.
-Jim
-Illogical. The fact that any airport *does* receive Federal money
-binds them to FAR 150 and specifically forbids granting exclusive
-aeronautical rights (i.e., refueling) under penalty of losing the
-Federal dole.
Old January 27th 04, 05:49 AM
Tony Woolner
Default autogas to 100ll
Thanks in advance!
Autogas and high end engines John Skorczewski Home Built 10 August 17th 04 06:19 PM
Hi Octane Autogas UltraJohn Home Built 24 April 18th 04 03:43 AM
Using 100LL in a Rotax 912 Engine Yosimite Sam Home Built 3 August 16th 03 05:00 PM
Hot weather and autogas? Rich S. Home Built 33 July 31st 03 12:25 AM
New autogas rules in the US Roger Halstead Owning 0 July 14th 03 09:37 PM
