Auto conversion cost post
Old December 20th 03, 08:07 AM
Richard Riley
Default Auto conversion cost post
Sometime recently (last 6 months or so) there was a post about how
much a well done auto conversion costs. The point was that if you're
doing it right - rebuild with race quality parts, proven PSRU, etc -
that the initial installation isn't significantly less than a zero
timed LyCont. (I think it's accepted by both sides that a rebuild
will be significantly less for the auto conversion, but that wasn't
the point)
IIRC, it broke down the costs to pretty small details. I've googled
but can't find it. Does anyone remember it, or is this a figment of
my sleep deprived imagination?
Old December 20th 03, 02:46 PM
Ben Haas
Richard Riley wrote in message . ..
the point)
Mine is running in the 14,000 dollar range. All new parts and the best
available technology one can buy. Less then half the cost of a Lyc
0-360, twice the output, no chance of shock cooling the cylinders,
safe and easy way of heating the cockpit. Rebuilds will be in the
1,100.00 dollar range. Thank god for being an American and having the
right to build an experimental plane with ANY kind of powerplant one
wants to use. Pics of the plane and motor will be in Jays site soon.
Happy holidays to all you plane lovers out there.
Ben Haas. N801BH. Jackson Hole WY.
Old December 20th 03, 07:35 PM
George A. Graham
timed LyCont.
snip
is this a figment of my sleep deprived imagination?
Richard, It certainly must be a figment of somebodys imagination,
and that person is convincing himself.
Horsefeathers!
George Graham
RX-7 Powered Graham-EZ, N4449E
Homepage http://bfn.org/~ca266
Old December 21st 03, 06:08 PM
Rick Pellicciotti
the point)
Richard,
We most often agree and I really don't have a horse in this race either
way but I see one flaw in your statement.
Comparing an auto engine built up with "race quality parts" to an
aircraft engine that is "zero timed" is not fair. There is nothing in a
zero timed engine built buy lycoming or continental that remotely
resembles the latest technology or "race quality parts" that you can buy
for an auto engine. Aircraft engines are 1930's technology. Not saying
that there's anything wrong with that, I fly behind a Jacobs radial
everyday. It just isn't apples to apples in my opinion.
Rick Pellicciotti
http://www.belleairetours.com
Old December 22nd 03, 04:24 PM
Corky Scott
On Sat, 20 Dec 2003 07:07:35 GMT, Richard Riley
the point)
Richard, I think this depends on who does the build: someone who sells
firewall forward units, or a homebuilder who does all the work
himself.
For a firewall forward unit, I've seen pricing up to $18,000 for
something making around 200 hp. For something like the Enginair 420
hp V8, that costs around $80,000 last time I looked.
For guys who want to do the work themselves, the cost can be
considerably lower. In my case, I expect my final cost will be
somewhere between $5,000 and $6,000 for a complete 190 hp running
engine installed in the airframe. The engine should be considered
zero timed.
Corky Scott
Old December 24th 03, 03:37 AM
Peter Dohm
the point)
I don't have a current interest in this issue ... yet!
However, when I do get started building, this will be a major issue, and
I have been reading, talking to chapter members and others, and even
contributing my 0.02 on occasion for some time.
Originally, I believed that the best way to convert an automotive engine was to
flip it over and drive directly through a quill shaft, in the manner of Steve
Wittman's conversion of a Buick/Olds aluminum V8 for the Tailwind. The lighter
castings in more recent 90 degree V8 and V6 iron block engines made the idea
seem reasonable for a long time. However, those relatively large, slow turning
engines that develop their peak torque at less than 3500 rpm are rapidly
becoming dinosaurs, and any dream of a retractable nose wheel starts to look
really nasty!
I still like auto engines, but doubt that the more modern ones will benefit from
the "conversion" process. Everyone who has posted here, and who claims to have
manufacturing experience, claims that they are routinely run at maximum rpm and
horsepower for extended periods during acceptance testing of the designs,
including some really atrocious warm-up procedures, and the major concern (and
proven failure mode) is the head gaskets. Therefore, the addition of racing
parts does not seem productive from my viewpoint, with the possible exception of
the head gaskets. Assuming that unleaded fuel will be available, at least most
of the time, every ECM being supplied is so much better than my own engine
management can ever be that there is no contest.
Therefore, my most recent thinking is leave the engine completely stock,
including all harmonic balancing and damping components; and supply it with an
offset reduction drive. Just my 2 cents.
Peter
Additional disclaimer: Just my current thinking, and a reserve the right to use
one of those heavy old inverted engines--resulting in a two seater with the
weight of a four seater ... or to consider a certificated aircraft engine.
Old December 24th 03, 04:02 AM
Morgans
Peter
Proper warm up before applying high loads, make this head gasket issue a
moot point. The engine must be heat soaked, prior to runup, and takeoff.
Old December 24th 03, 01:02 PM
George A. Graham
I agree Peter, I also used the stock 5spd transmission as a psru, but did
use a lighter flywheel.
Over five years flying, almost 400 hours, I love it!
George Graham
Old December 25th 03, 11:03 PM
Ben Haas
So George, fill us all in on how you took a 5 speed trans and used it
to transmit 500-600 pounds of thrust from the prop when in a car there
is no thrust loads on the output shaft at all??
George A. Graham" wrote in message ...
George Graham
Old December 27th 03, 02:03 PM
George A. Graham
Sure Ben, Single deep groove bearings, and it is more like 300 lbs.
The stock output shaft is not used (too long).
George Graham
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Aircraft per hour cost Fitzair4 Home Built 0 December 1st 03 03:15 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
