Best PDA/PNA for FLARM display?
Old August 24th 11, 03:47 PM posted to rec.aviation.soaring
Frank Paynter[_2_]
Default Best PDA/PNA for FLARM display?
I flew with a portable PowerFLARM at the Uvalde pre-worlds, and I have
a 'brick' unit on order for delivery sometime this fall/winter. As I
wait for delivery, I am contemplating how to integrate it into my
current instrumentation setup.
One possibility I am considering is to not use the brick's Butterfly
display at all, assuming I can get adequate display/warnings from
FLARM data displayed on one of the many PDA/PNA moving map displays
available these days.
Does anyone have experience with FLARM display on WinPilot PRO v9,
SeeYou Mobile on an Oudie or other display, ClearNav, or other? Is
the integrated display good enough to replace the Butterfly display?
TIA,
TA
Old August 24th 11, 04:10 PM posted to rec.aviation.soaring
Andy[_1_]
Don't only consider the threat display capability. You also need the
audio alarms and the control functions some of which, I think, will
require the display of separate settings pages. Some alternate
display devices may support all the required functionality but it
seems unlikely that anyone would have been able to test that yet.
Andy
Old August 24th 11, 04:30 PM posted to rec.aviation.soaring
Dave Nadler
The ILEC SN10 optionally displays 2 FLARM pages:
- threat (giant graphic for fast visualization of threat direction), and
- neighbors (kinda like PF "radar" display, no map overlay)
I used it at Uvalde, and as a few bozos tested collision
warnings for me so I can attest it works great.
I understand ClearNAV has something similar.
Most if not all current PDA software has FLARM displays...
Hope this helps,
Old August 24th 11, 04:33 PM posted to rec.aviation.soaring
I haven't studied any PDA/FLARM interface except LK8000. I assume other
software have similar capabilities and limitations. I have come to the
conclusion that the Butterfly display provides an instant view that isn't
available on the PDA and the PDA provides additional information not
available on Butterfly.
The following link provides information that may assist in your research.
http://www.bware.it/LK8000/LK8000_MANUAL_122.pdf
My current plan is to connect the PowerFLARM brick data to my PDA via serial
cable and my smart vario data via BlueTooth.
HP-14 "6F"
http://tinyurl.com/N990-6F
"Frank Paynter" wrote in message
TIA,
TA
Old August 24th 11, 05:00 PM posted to rec.aviation.soaring
John Cochrane[_2_]
a 'brick' unit on order for delivery sometime this fall/winter. *As I
SeeYou Mobile on an Oudie or other display, ClearNav, or other? *Is
TIA,
TA
Clearnav shows surrounding traffic, but like the others I have seen
(winpilot, seeyou), the display is designed to complement, not
substitute for, the collision display.
I connected powerflarm to clearnav at Uvalde. The good news is, it
works. Clearnav shows the other gliders. But when there is a collision
alert powerflarm shows you which glider is the problem by making the
other glider larger and red. Clearnav (for now) doesn't show which
other glider is causing the interference. The CN display is also not
designed to take over the functionality of the big powerflarm button.
Of course with powerflarm in the US for a grand total of about 3 weeks
so far, it's an easy bet that the other software will all be modified
over the winter to take better advantage of it. Still, conventional
wisdom seems to be to put the PF display somewhere where you can see
it.
John Cochrane
Old August 24th 11, 05:24 PM posted to rec.aviation.soaring
Paul Remde
Hi Frank,
SeeYou Mobile and your ClearNav can currently display FLARM traffic and
climb rates, etc.
I'm not aware of any soaring software or hardware that can currently display
the ADS-B or transponder traffic data from the PowerFLARM. I'm not certain
whether or not the PowerFLARM will send ADS-B and transponder traffic data
out. I am optimistic that it will do so in the long run. I'm also
optimistic that soaring software will be able to display the ADS-B and
transponder traffic data in the long run. Until then, I highly recommend
using a PowerFLARM display in your cockpit. It would be a shame if the
PowerFLARM was trying to alert you to nearby ADS-B or transponder traffic
and you weren't listening.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
TIA,
TA
Old August 24th 11, 05:37 PM posted to rec.aviation.soaring
Darryl Ramm
PowerFLARM does not yet send out serial-port data on ADS-B traffic or PCAS alerts. That is under developed by FLARM. Third party vendors will have to add support for those Flarm enhancements.
There is a lot of detail to ask about when looking at different FLARM 3rd party software integration. What exact feature of FLARM and PowerFLARM (especially) does it support, e.g. does it support FLARMNET - the ability to tie glider information to an Flarm/ICAO ID etc. (and I'm not even sure if that will be used in the USA - I hope so).
Be very careful of any third party vendor who just says "we support Flarm" that is a pretty useless level of detail. You have to look in detail, often at the user manual to see exactly what is there and what works.
I am looking at SeeYou Mobile talking to a PowerFLARM in front of me at the moment. I see the Flarm rings but no Flarm equipped gliders flying nearby....
Darryl
Old August 24th 11, 05:54 PM posted to rec.aviation.soaring
Paul Remde
Hi Darryl,
Good points.
I know that SeeYou Mobile does support FLARMNet. You just download the
FLARMNet data file and save it in the "Radar" directory on the PDA or PNA.
The PowerFLARM display currently does not support FLARMNet. It may in the
future.
I don't know whether or not the ClearNav supports FLARMNet.
I have registered my PowerFLARM on FLARMNet. It is pretty easy to do.
FLARM recommends using your gliders ICAO ID - which is easy to get. But you
do need to convert it to a Hex number. That is easy if you know how. The
calculator in Window can make the conversion. The PowerFLARM manual shows
where to get your ICAO ID from the FAA web site.
Paul Remde
"Darryl Ramm" wrote in message
Darryl
Old August 24th 11, 06:09 PM posted to rec.aviation.soaring
Richard[_9_]
TIA,
TA
Frank,
I have been testing PowerFlarm Portable with the following hardware
and software
Craggy Aero Ultimate Le
LX1606 Vario
SeeYou Software
PowerFlarm is powered by and connects directly to the LX1606 vario.
The LX1606 receives the NMEA stream from the PowerFlarm and adds its
own sentences. RX & TX to the Ultimate Le thru the serial port.
The system works and is valuable for the read out of Altitude and
climb rate, you can also assign Contest Id with Seeyou and colors for
above and below.
I still believe the PowerFlarm display or the ButterFly display will
give you a more intuitive and timely threat alert display. I am
advising customers to have one of these displays in addtion to
connection to the Ipaq/PNA.
Richard
www.craggyaero.com
Old August 24th 11, 07:54 PM posted to rec.aviation.soaring
Darryl Ramm
TIA,
TA
This has seen covered on r.a.s before, but you absolutely need a
PowerFLARM portable (with built in display) or the brick with external
Butterfly display. You will not be able to operate a PowerFLARM brick
say just driving a PDA or flight computer. There is no software
interface for those 3rd party systems to use control the setup and
operation of the PowerFLARM, and for safety reasons the PowerFLARM is
just not intended to be used without a primary Flarm collision avoidance
display. Put that display as high up on your panel or glare shield so it
can be glanced at quickly.
Darryl
FLARM Robert Hart Soaring 50 March 17th 06 12:20 AM
FLARM John Galloway Soaring 9 November 27th 04 08:16 AM
