Time (years) SMOA
Old March 20th 04, 07:08 AM
Paul Folbrecht
Default Time (years) SMOA
The 150 I had pre-buy'ed today has an O-200 with 940 SMOA but this
overhaul happened 24 years ago. Mechanic has pointed out that
Continental also specifies a time limit of 12 years on overhaul and thus
this engine is technically runout.
Do I have much cause for concern?? I know engines are quite regularly
run well beyond that time interval. After all, to make that 1800 hours
in 12 years you have to fly 150 hours/year.
Compression is good (all in the 70s) but there is no oil analysis
available. Engine sounds just fine and also has good oil pressure.
I basically need to make a decision on this quickly and am stuck on this
issue. I am leaning heavily towards buying it. My mechanic has said it
is pretty unlikely that this time factor will result in serious problems
now, but that there's really just no way to tell without an oil analysis
or by watching oil consumption.
Old March 20th 04, 07:22 AM
BTIZ
The fact that the engine may be "old" is a factor in trying to establish an
agreeable price between you and the seller. Even though all the magic
numbers may seem good today. Oil analysis, compression, etc... 900 hours in
24 years is 1/2 the usage rate recommended. Engines that sit can rust
internally and that cannot be found without either cracking the case or
pulling one cylinder and looking around inside with a bore scope.
Consider it a bargaining point on establishing the price, and be prepared to
rebuild the engine within one year.. worse case. Best case?? you get
another 1000 hours out of it. Make it a bargaining point that the engine is
3/4 or more used up and not 1/2 because of its age is twice what the
manufacture recommends.
If the seller decides not to budge on the price. It is your decision and
yours alone to pay the asking price. That's why owners get to make
decisions.
good luck
BT
"Paul Folbrecht" wrote in message
k.net...
Old March 20th 04, 01:19 PM
Michelle P
Paul,
I would consider the engine of $0 value in negotiating. That is an
average of less than 40 hours a year. Usage pattern is of concern as
well. If it sat for the last several years, very bad. If it was run
regularly to full operating temperature for the past few years, and
still runs good. this is better. Was the engine preserved when not run
for period of time?
Michelle
thus this engine is technically runout.
hours in 12 years you have to fly 150 hours/year.
this issue. I am leaning heavily towards buying it. My mechanic has
said it is pretty unlikely that this time factor will result in
serious problems now, but that there's really just no way to tell
without an oil analysis or by watching oil consumption.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old March 20th 04, 01:50 PM
Stu Gotts
On Sat, 20 Mar 2004 06:08:10 GMT, Paul Folbrecht
Technically yes, in actuality it's bull****
You're correct. Ever think about how many people actually fly 150 per
year? I think the average was 40 or so. You should look at TT on the
engine itself, not just SOH.
Both good indicators. Start the oil analysis after you buy it.
If worse comes to worse, you can get another mid time engine rather
inexpensively. Good luck. Go for it.
Old March 20th 04, 02:57 PM
Mike Spera
I'm sure you will get responses saying not to worry. Those will be from
others who have similar numbers and have not (yet) had a problem. Yes.
Engines can be run well past TBO IF they are "overflown". For example,
an engine run for 100 hours per MONTH (a.k.a. "trainer") can get 3000+
hours before going downhill. The one in question got 40 hours a YEAR.
I suspect the reason some consider a plane like this is because it is
close by, or because they don't have the cash to get one with better
numbers.
If the former, I would keep looking. If the latter, they are likely to
buy a plane and then be stuck when the engine craps out (soon) because
they are out of cash to make it right. I have seen many of them on the
local airports lately. Some buyers are so eager to get it over with and
get an airplane they take a risk like this. In normal life, they would
not even consider a similar risk on say, a house or a car.
Engine "sounds" good, compressions "good", and has "good" oil pressure
are all static observations. All these things are true right up until
the second they begin to deteriorate. Over the course of a few operating
hours, compressions can rapidly decline and oil consumption can also go
up quickly, and an engine can start grinding itself to pieces and making
metal at any time.
It all depends on what risk you are willing to take and how much cash
you have. I personally don't like any engine past about 500 hours and 4
or 5 years SMOH. That's just me. I'll pay the price. A ready to go bird
is almost always less expensive than getting it done on your dime after
the purchase.
Trouble is, if you try to deduct the price of a major overhaul, chances
are the seller will balk. And, someone with the cash who does not know
enough or care enough about the engine times will buy it up from under you.
Good Luck,
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
Old March 20th 04, 04:25 PM
Paul Folbrecht
Thanks, Stu. Engine TT is 4200. I already got the got to come down
from $15K from $19K due to other things. He's not going a dime lower -
I know that.
The lack of an oil analysis is bugging the heck out of me right now,
though.
As for sitting for a long period - it doesn't appear to have done that.
Just below-average usage over the last two decades.
Old March 20th 04, 04:29 PM
Paul Folbrecht
numbers.
In part it's the former. Not the latter. He wants $15K for this '71
150 with 6200TT. And my mechanic says the first annual will run $4K -
$5K. That's how I got him down from the $18-$19K range he was in.
Deducting the price of a major puts the airplane at $2,000!!
Good Luck,
Old March 20th 04, 04:30 PM
Paul Folbrecht
It was never not run for years at a time.. just a low overall usage pattern.
Michelle P wrote:
Paul,
for period of time?
Michelle
Old March 20th 04, 05:50 PM
BTIZ
Paul... looks like your going to get the best price at $15K...
as stated before.. you could be lucky with the engine.. or not..
set up a deposit.. offer a free oil change and go get it checked
if it comes back clean... that's good for today..
as an owner.. you will always need to be prepared for a complete engine
overhaul
BT
k.net...
numbers.
you.
Good Luck,
___
Old March 20th 04, 05:57 PM
Paul Folbrecht
You're absolutely right, of course. I decided against it. There's no
reason to chance this when I know there are enough 150s/152 out there
with much fresher engines (in years, not operating time). I'll wait.
One other thing I didn't mention: the paint stinks. It was applied
poorly, with apparantly no surface prep. It is chipping off in several
places.
overhaul
BT
k.net...
numbers.
you.
Good Luck,
___
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Records Show Bush Guard Commitment Unmet WalterM140 Military Aviation 53 September 13th 04 06:49 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
