LIghtweight starter recommendations for PA24-250?
Old April 1st 04, 07:19 PM
Chris Kennedy
Default LIghtweight starter recommendations for PA24-250?
I'm coming up on annual time for 24P, and as usual I'm planning to take
advantage of the fact that the thing is taken to bits to make some
improvements. On the list this time around are new fuel cells, new gear
harnesses and switches (since there's no evidence that they've ever been
replaced and visual evidence that the harnesses are deteriorating) and a
new starter. It's the latter category that I'm looking for suggestions.
The obvious choices are various offerings from SkyTec, Magnaflight and
B&C. SkyTec is pushing their new inline starter for the PA24, but being
a new offering and in the same street price range I'd probably be
inclined to go with the B&C simply because it has more time in service.
I was curious what other Comanche 250/260 drivers were doing in this
regard (and before someone suggests it, the ICS/Delphi forum has been
less than useful in this regard)
Old April 7th 04, 07:16 AM
hs
I had G&N put in a Skytec when they overhauled the io540 in my pa24-260.
I'm glad I did it. Its biggest advantage has been on hot starts. They are
just not a problem anymore. One downside, though minor, is that there seems
to be less torque available. I find myself needing to "bump" or "rock" the
starter to get it over the first compression hump; then it cranks at a fast
pace.
I must admit I didn't do a lot of research into other starter alternatives.
Let's keep those pa-24's flying...
Harry
"Chris Kennedy" wrote in message
Old April 7th 04, 08:54 AM
Ben Jackson
I'd have to check the records to see what starter I have, but I do know
that the previous owner installed the 'copper cable STC', which replaces
the wires from the battery to the firewall. I've heard that starting
problems cured with new starters often expose weaknesses in the electrical
system.
Ben Jackson
http://www.ben.com/
Old April 7th 04, 05:47 PM
Chris Kennedy
Ben Jackson wrote:
[snip]
system.
Yeah, been there, done that. Since installing the copper cables I can
almost taxi the aircraft on the old Prestolite starter -- when the
bendix decides to engage. Rather that perpetually
cleaning/lubing/replacing the thing I just want to junk the Prestolite
in favor of something bendix-free but would like to be sure that I
select something that (a) is going to fit properly and (b) isn't simply
going to be a fresh sort of hell
Old April 8th 04, 01:01 AM
John Galban
Chris Kennedy wrote in message ...
I believe that the Sky-Tec is the only lightweight that is
Bendix-free. The Magnaflite and B&C use the traditional Bendix
arrangement.
John (Bendix-hater) Galban=====N4BQ (PA28-180)
Stuck starter solenoid? Paul Lee Home Built 4 April 16th 04 03:58 PM
Starter selection -- seeking input [email protected] Owning 3 April 5th 04 01:43 AM
paint shop recommendations wanted (SE) Stephen N Mills Owning 0 January 29th 04 04:44 PM
Sticking Starter Wayne Owning 5 September 2nd 03 08:26 PM
