172 door hinges: right way, wrong way, my way???
Old April 2nd 04, 04:18 PM
Mike Z.
Default 172 door hinges: right way, wrong way, my way???
I was walking around the old girl yesterday and the doors were hanging open to make sure all the moisture from the leaks (stand-by
for post on cabin leaks)....so anyway, something made me grab the bottom of the door and check sop in the hinges. Maybe it was
because I am thinking of taking them off to replace the seals someday to slow down the wind blowing through.
Anyway, I pull up on the back of the door and the bottom 1/2 of the hinge pins falls down a 1/4". Hmmm.
The top hinge pins look stock, but the lowers look like a piece of coat hanger. Not even tractor pins like the rentals!
What do you use for pins material?
Mike Z
Old April 3rd 04, 02:46 AM
Dan Thomas
"Mike Z." wrote in message link.net...
Mike Z
We buy pins from Cessna. One of them is a stainless pin, the other is
brass and looks just like uncoated brazing rod. Real expensive brazing
rod, it is. The Cessna manual calls for "spin-bradding" of the pins to
keep them in the hinge, and I made a 1/4" rod with a taper on one end
and a small hemispherical depression in the same end, and spun it with
a die grinder. Hold the pin down in the hinge, and the high speed of
the rod against the other end of the pin will heat and upset it,
forming a head.
The stainless pin doesn't care for this treatment. The brass works
well.
Dan
Old April 3rd 04, 03:27 AM
Jim Weir
I personally prefer cotanger material for the early 172 hinges.
Cut it about 1" longer than the hinge, bend the top ½" over at about a 10°
angle, insert it into the hinge, and then bend the bottom ½° at the same angle
http://www.rst-engr.com
Old April 3rd 04, 05:58 AM
jsmith
Wow!
You sure use that antenna material for a lot of things on an airplane.
What else does it do?
Cut it about 1" longer than the hinge, bend the top *" over at about a 10°
angle, insert it into the hinge, and then bend the bottom *° at the same angle
Old April 6th 04, 09:07 PM
Mike Z.
Thanks!
Hopefully a little oil will keep the replacement lasting a little longer too.
Mike Z
"Jim Weir" wrote in message ...
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Naval Aviation 5 August 21st 04 01:50 AM
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Military Aviation 3 August 21st 04 01:40 AM
ATC says wrong position Greg Esres Instrument Flight Rules 28 April 30th 04 06:37 PM
Were the Tuskeegee Airmen Wrong? Stephen Harding Military Aviation 63 February 14th 04 08:38 PM
Wrong Brothers Air Force Party Invite Jay Honeck Home Built 1 July 20th 03 11:55 PM
