ARC Cessna 328 Aux Audio Inputs
Old April 15th 04, 05:15 AM
N7155A
Default ARC Cessna 328 Aux Audio Inputs
Under the supervision of my IA, we installed a vor radio. I connected
the vor audio output to one of the Aud-Audio inputs on the RT328D,
thinking this would supply audio to the intercom (connected to the
RT328 phone output) and the speaker.
The VOR radio output only appears to go to the speaker (via RT328D).
I expected these aux-audio to go to the rt328 phone output, but that
doesn't appear to be the case. I guess I need to get an rt328
instruction manual or schematics to determine the function of the
aux-audio inputs.
Any help would is greatly appreciated.
Mitch
Old April 18th 04, 10:41 PM
John
You are correct. The Aux inputs go directly to the 328 speaker
amplifier. If you do not have all of the switch positions on the
audio panel filled you can add a PCB mount switch to the audio panel
to switch in your new audio source. This is what I did for my 2m ham
radio that I installed in my Cessna. The only place I have found the
schematic for the audio panel is in the "74 through 76 avionic
installations' manual.
aux-audio inputs.
Mitch
Old April 21st 04, 10:25 PM
N7155A
Thanks for your input John. The plane does not have an audio panel,
and uses a 2 place portable intercom.
The RT328 Phone output is tied back to an auxilary input to get to the
speaker amp. I think I'll connect the VOR2 audio to the 328 phone
output through 100ohm resister. This will feed it to the headset and
the speaker output, and avoid loading of the outputs. We will use the
volume controls in lieu of audio panel switches.
Mitch
(John) wrote in message
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 04:40 PM
Cessna buyers in So. Cal. beware ! Bill Berle Aviation Marketplace 93 December 20th 04 03:17 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 01:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 01:57 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
