Archer high oil temp
Old June 6th 04, 03:11 AM
Mike Noel
Default Archer high oil temp
Now that summer has come to Arizona, my oil temp is running about 2/3 of the
way between 180 and red line. My mechanic checked the oil cooler bypass
valve and said it was OK, so I had decided to send in the oil cooler for
cleaning and service. Checking the engine log for the last time work was
done on the cooler, I found an entry about 5 years ago saying the cooler had
been cleaned, then the next entry said the oil temp gauge was reading about
20 degrees too high, but there is no entry for corrective action to the oil
temp guage, wiring, or sender.
Looks like I need to check the gauge system myself for accuracy and probably
replace something. Do you just drop the sender into hot water and compare
the panel guage reading with a couple of cooking thermometers? If there is
a discepancy, is it the sender that should be replaced first, then replace
the guage if necessary?
Regards,
http://mywebpage.netscape.com/amountainaero/fspic1.html
Old June 6th 04, 05:00 AM
zatatime
On Sat, 5 Jun 2004 18:11:32 -0700, "Mike Noel"
I need to do the same thing with my bird. I don;t have all the
answers, but am planning on using engine oil instead of water. It
will allow me to bring the temp up to 250, or 300 so I have a better
idea of what temps may be affecting the sender.
If you have a sender you can swap with try that so you know which part
is defective. If you don't (like me) I plan on swapping the sender
first cause it's cheaper than a gauge.
HTH.
z
Old June 6th 04, 05:05 AM
Rip
Boiling water won't hurt the sender, and you know that's exactly 212 deg.
HTH.
z
Old June 6th 04, 05:39 AM
Only at an absolute pressure of 29.921; but there are lots of
charts/caclulators on the Internet to correct for pressure and altitude.
Jim Pennino
Remove -spam-sux to reply.
Old June 6th 04, 03:18 PM
Unless things have changed substantially, the sender/gage setup on the
older Pipers is a real pain. The sender & gage p/n/vendor/working
resistance has changed over the years, and Piper didn't useta be much
help in sorting it out.
The first step would indeed be to get a replacement crush gasket and
yank the sender and boil it. If the boiling water trick (don't forget
to ground the sender) reveals an indicating problem, the easiest thing
to do is contact Air Parts of Lock Haven.
http://www.airpartsoflockhaven.com/
Again, it's been a few years, but they were quite helpful in sorting
out the mess. It is possible that the wrong sender has been installed
at some point, or that the "right" sender for your gage is no longer
available. In either case, they can calibrate your gage and "match" it
to either a new sender, or your sender if it is functional.
TC
Old June 6th 04, 07:14 PM
Chris Kennedy
Not up here at altitude you don't
Oil also lets you check the vernatherm while you have the stove out
(mine proved to be defective) without tossing that particular hunk of
metal into a water bath...
Old June 9th 04, 01:18 AM
Jeff
Thats just the summer heat.
I fly a turbo arrow, currently in las vegas, moving to phoenix in about 3 weeks.
my mechanic says as long as I dont redline the temps its not a problem, but at
different altitudes I do pull the power back a little and level off to cool the
engine down some.
Regards,
Old June 15th 04, 04:38 PM
H. Adam Stevens
"Mike Noel" wrote in message
had
about
oil
probably
is
Regards,
Hi Mike
You can check the calibration of the gauge with a precision resistor in
place of the sender for virtually no effort past finding the appropriate
resistor.
I can check what it was in my Seminole but I don't have the book at my
office and that was years ago and YMMV.
The right engine on N2196B always appeared to have a higher oil temp.
I spent much more on mechanics than it cost me to find out the gauge was
wrong; I still have an oil cooler in my garage.
If the gauge looks right then immerse the sender in oil on a hot plate with
a real thermometer and check it accurately.
Blue skies!
H.
H. Adam Stevens
CP AS&MEL IA
ex N2196B PA44-180
and a damned nice bird she was
FS: 1988 "Aces High" (Military Airplanes) Hardcover Edition Book J.R. Sinclair Aviation Marketplace 0 August 23rd 04 06:18 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 04:33 AM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 04:35 AM
High Flight NOTAM Kirk Stant Military Aviation 1 September 10th 03 04:31 AM
