High Oil Pressure (was: Low oil pressure, high oil temp?)
Old October 4th 04, 05:40 PM
Thomas Ploch
Default High Oil Pressure (was: Low oil pressure, high oil temp?)
What about high oil pressure. My factory zero time O-235C1 is running
at around 90 psi in cruise. This is at the very top of the allowed
range.
Oil Pressure Limits - (Normal operations) Minimum 60 p.s.i. Maximum 90
p.s.i.
(Idling 25 p.s.i.)
(Starting & Warm-up) Maximum 100 p.s.i.
Is this a problem?
Old October 4th 04, 11:52 PM
NW_PILOT
"Thomas Ploch" wrote in message
om...
range.
p.s.i.
(Idling 25 p.s.i.)
Is this a problem?
I'd say no not a problem. I would rather have it at the upper part of the
range then at the lower.
Old October 5th 04, 01:26 AM
My understanding is that this is normal for newly rebuild engines. We are
seeing the same thing on our new (lyc. factory reman.) IO-360.
-Elliott Drucker
Old October 5th 04, 01:39 AM
Rip
The bearing clearances in a freshly overhauled engine are as tight as
they will ever be. And the oil pressure is as high as it will ever be.
If it's in the green, fly it.
range.
p.s.i.
(Idling 25 p.s.i.)
Is this a problem?
Old October 5th 04, 05:34 AM
J. Severyn
om...
range.
p.s.i.
(Idling 25 p.s.i.)
Is this a problem?
No problem. My 300 hour since factory overhaul O-235-L2C also runs 85-90
psi in cruise.
J. Severyn
Low oil pressure, high oil temp? Roy Smith Owning 9 October 4th 04 12:02 AM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 09:04 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 06:18 AM
