Masterswitch details
Old December 4th 04, 08:35 PM
ShawnD2112
Default Masterswitch details
Hello! I'd like to ask the help of the assembled exeprtise here about the
details of the standard two-sided Cessna masterswitch.
I'm rewiring my Pitts to put a B&C alternator in it. I've got a two-sided
switch and can't remember which side is the battery side and which is the
alternator side. Also, there are two contacts on a couple of points on the
switch and i'm not entirely sure what they're for.
So, does anyone know where I could get a schematic of the workings of this
type of switch? If not, how about just a good explanation of how it works.
Failing that, I'd just be happy to be reminded of which is the battery and
which is the alternator side. Basically, any info anyone can provide will
be greatly appreciated!
Cheers,
Shawn
Pitts S-1D, G-BKVP
Old December 5th 04, 03:06 AM
Mike Granby
The side that can be switched on by itself is the battery; the side
that is physically interlocked to turn both sides on when activated is
the alternator. The idea is that you can have the battery on without
the alternator, but you can't have the alternator on without the
battery.
The battery side controls the coil of the master solenoid, and thereby
connects the battery to the main power bus. The alternator side
switches the power to the alternator field coils, typically via the
voltage regulator and over-voltage relay, and thereby effectivly
switches the alternator on or off.
TACAIR Integration - any details, or speculations only? [email protected] Naval Aviation 0 November 22nd 04 01:46 PM
Paint for interior details Frode Berg Owning 1 June 14th 04 02:19 AM
BEN GELMAN: WWII BOOK DETAILS AIR CORPS VETERANS' POSTWAR LIVES Otis Willie Military Aviation 0 October 30th 03 09:08 PM
Oshkosh Rec.Aviation Get-together details... Jay Honeck Home Built 2 August 3rd 03 05:31 PM
Oshkosh Rec.Aviation Get-together details... Jay Honeck Owning 2 August 3rd 03 05:31 PM
