PA32-260 Auto Fuel STC
Old January 5th 05, 01:38 AM
Bruce McFadden
Default PA32-260 Auto Fuel STC
Does anyone know if there is an STC for use of auto fuel in a PA32-260.
I've been unable to find one. At $3.30/gal for avgas at KBHM I've got
to stop the bleeding a bit.
Thanks in advance.
Bruce McFadden Birmingham, AL
PA32-260 N5594J
Old January 5th 05, 05:34 PM
Ron Natalie
The two auto fuel stc holders are Petersen and the EAA.
Neither of them do the PA-32 (or any twins to my knowledge).
Old January 5th 05, 05:39 PM
Ron Natalie
Whoops, the PA-32 isn't a twin, my bad. Still neither the EAA nor
Petersen have an STC for it.
The URLS a
http://www.eaa.org/education/fuel/ for the EAA
and
http://www.autofuelstc.com/ for Petersen.
Petersen used to have a list of airframes tested and failed but I can't find it.
You might email them. They do support some O-540 models (this is what you have
right?) but the airframe isn't listed.
Old January 5th 05, 06:01 PM
Jay Honeck
find it.
you have
My O-540 is approved for car gas.
It's got to be the low-compression version to be eligible.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 5th 05, 06:11 PM
Ron Natalie
find it.
you have
The PA-32-260 engine variant (E4B5 or whatever) is in Petersen's list as one of the 91
octane engines. However, the airframe isn't approved.
Old January 5th 05, 07:11 PM
Jay Honeck
one of the 91
That sucks. Guess I'll never buy a Six.
How does an airframe difference matter to what fuel the engine uses?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old January 5th 05, 07:28 PM
Ron Natalie
one of the 91
Fuel lines, fuel pumps, and vapor lock issues. Lots of information on this
on the Petersen web pages if you want the details. They don't do Navions
(with any sort of engine). I asked for details once and the emailed me back
that they had tested it and it failed the vapor lock tests. I asked for
further configuration information because even with the E-185 (original Navion
engine) there were two different fuel configurations (that's the difference
between the Navion and Navion A), and then there are other engines (also on the
approved list) that the factory and/or outsiders have added.
Old January 5th 05, 08:47 PM
G.R. Patterson III
It's now buried in the text. Click on the word "airframes." The URL is
http://www.autofuelstc.com/autofuels...Airframes.html
Still, they have a note there to call them if you don't see your plane listed.
Apparently they have STCs for some aircraft that are rare.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old January 5th 05, 09:41 PM
nrp
I know anecdotally from my IA that some of the Cherokees are somewhat
marginal in their ability to handle the high vapor pressures of winter
autofuel. They would stumble on takeoff & climbout the first hot days
of spring.
The symptoms that I had heard sounded more like flooding rather than
fuel starvation. It could be that the floats were sinking in the carb
bowl as the fuel was boiling. The front of the bowl is close to very
hot exhaust pipes, and the bowl vent is back directly into the air
intake. Any one else know any more than this?
I had heard some of the Grummans have had the autofuel STC pulled for
similar reasons.
Those of us using the autofuel STCs have to be cognizant of its
possible limitations. It has worked well so far in my 172M (about 15
years), but I avoid flying in very hot weather and avoid parking bright
sun (being concerned about fuel tank heating) just on principle. I'll
let someone else verify that experiment.
Pilots talk about the vapor pressure as though it is an absolute
measure. It is not as it doubles about every 15 degreesF. Raising a
fuel temp 15 degrees F will increase the actual vapor pressure of avgas
enough to eliminate the measured reduced pressure benefit of avgas. In
other words, autofuel has a 15 deg F handicap in handling high fuel
temps.
Octane requirements are a separate issue. The 235 HP Cherokee is an 80
octane engine, the 260 requires higher octane than regular.
(Petersen is no relation to me)
Old January 5th 05, 11:46 PM
nrp wrote:
: I know anecdotally from my IA that some of the Cherokees are somewhat
: marginal in their ability to handle the high vapor pressures of winter
: autofuel. They would stumble on takeoff & climbout the first hot days
: of spring.
True enough of any aircraft, but the Cherokees' stock fuel system is a bit
marginal to begin with. We got the STC for our 180 HP O-360 Cherokee and it required
electric boost pump replacement. After that, we never got reduced fuel pressure at
full power, full-rich, max nose-high attitude like we did with the stock pump. To
give you another piece of info. If you have an O-320 *low-compression* (150hp), you
get the 87 AKI autogas STC and keep the stock fuel pump. If you do *NOTHING* but swap
pistons in the engine and turn it into a 160 hp, you need to swap out the fuel pumps
due to "flow" issues. There's no difference in fuel flow by putting in
high-compression pistons since everything else is kept constant.
: The symptoms that I had heard sounded more like flooding rather than
: fuel starvation. It could be that the floats were sinking in the carb
: bowl as the fuel was boiling. The front of the bowl is close to very
: hot exhaust pipes, and the bowl vent is back directly into the air
: intake. Any one else know any more than this?
Sounds reasonable. I talked with Petersen about this and he said that the
PA-24 (Commanche) failed due to "hydro-locking." Boiling fuel in the carb sinking the
float would certainly cause flooding and hydro-locking.
: I had heard some of the Grummans have had the autofuel STC pulled for
: similar reasons.
Quite possible. They're a bit tigher cowled than the PA-28's.
: Those of us using the autofuel STCs have to be cognizant of its
: possible limitations. It has worked well so far in my 172M (about 15
: years), but I avoid flying in very hot weather and avoid parking bright
: sun (being concerned about fuel tank heating) just on principle. I'll
: let someone else verify that experiment.
Absolutely. I'm especially leary of the octane rating for the
high-compression STC (like I have). Most autogas with a 93 rating only has an 88 or
so *motor* rating... which is similar to the avgas lean rating. As such, I like to
have some 100LL in at least the takeoff tank... particularly on hot days.
Also, autogas tends to have trace amounts of gunk/water in it. A screw-on
water-separating filter on the gascan lids took care of that.
: Pilots talk about the vapor pressure as though it is an absolute
: measure. It is not as it doubles about every 15 degreesF. Raising a
: fuel temp 15 degrees F will increase the actual vapor pressure of avgas
: enough to eliminate the measured reduced pressure benefit of avgas. In
: other words, autofuel has a 15 deg F handicap in handling high fuel
: temps.
True. Petersen sells a vapor pressure tester. Basically just a syringe
with a screw-on gauage that you can pull a vacuum on a fuel sample until it boils.
I always see 100LL about 1" higher than autogas, but on all but the ugliest days the
autogas reads in the green on the gauge.
: Octane requirements are a separate issue. The 235 HP Cherokee is an 80
: octane engine, the 260 requires higher octane than regular.
: (Petersen is no relation to me)
I think the PA-32 can have the O-540-E4B5... that's on the 91 engines list. No PA-32
that I can see on the airframe list.
* Cory Papenfuss *
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
Auto Fuel STC Jeff Home Built 62 September 24th 03 03:41 AM
A interesting bit of auto fuel info. Stealth Pilot Home Built 0 September 22nd 03 11:34 AM
