Transponder reminder: 1202, do NOT ident unless requested by ATC
Old February 7th 12, 11:19 PM posted to rec.aviation.soaring
Dave Nadler
Default Transponder reminder: 1202, do NOT ident unless requested by ATC
Reminders from the SSF/SSA safety briefing at Reno:
(1) The 1202 transponder code for gliders is effective
nationwide this week. Do contact your local ATC and
make sure they are expecting this...
(2) Do NOT press IDENT unless specifically requested
to do so by ATC.
Lets all be good neighbors out there,
Old February 8th 12, 04:47 AM posted to rec.aviation.soaring
Uwe Kleinhempel
to do so by ATC.
Old February 8th 12, 07:09 AM posted to rec.aviation.soaring
zulu
to do so by ATC.
Best Regards, Dave "YO electric"- Hide quoted text -
- Show quoted text -
Dave:
I went to the FAA web site to look for the new order which should be
JO 7110.66E, but found nothing but the old order (just subtract one
letter from the end of the one I've just mentioned.) One would think
that the Feds would have the current order posted along with the
effective date. On the other hand they may be waiting until Feb. 9 to
make it available on the internet to the un-washed masses.
I'll check again after that date.
Zulu
Old February 8th 12, 03:36 PM posted to rec.aviation.soaring
Dave Nadler
Apologies, I'm repeating what was briefed,
but I did not get the relevant publication ID.
It would be great if anybody can find it...
Effective date is 9-February.
Best Regards, Dave
Old February 8th 12, 05:23 PM posted to rec.aviation.soaring
Mike the Strike
Best Regards, Dave
We have received confirmation from Tucson TRACON to change our
dedicated glider transponder code from the present 0400 to the new
National 1202 on February 9th. Our President asked for this
confirmation from them, but they have obviously been informed.
Old February 8th 12, 07:33 PM posted to rec.aviation.soaring
Rick Fuller
I was shown a set of initial documentation changes back in May 2011. Don't
know if the final changes were similar. I'd be happy to send anyone a .pdf
copy of those changes. Email me at rick dot fuller at cox dot net for a
copy.
Rick "CL"
Dave:
Zulu
Old February 9th 12, 01:49 AM posted to rec.aviation.soaring
T[_2_]
On Feb 8, 10:33*am, Rick Fuller
I was shown a set of initial documentation changes back in May 2011. *Don't
know if the final changes were similar. *I'd be happy to send anyone a ..pdf
copy of those changes. *Email me at rick dot fuller at cox dot net for a
copy.
Rick "CL"
Dave:
letter from the end of the one I've just mentioned.) *One would think
effective date. *On the other hand they may be waiting until Feb. 9 to
Zulu- Hide quoted text -
On 2 Feb 2012, Notice JO7110.577 was signed out by the FAA informing
all ATC facilities to monitor the 1202 Glider Code, effective on 7
March 2012.
I could only find 7110.66D which lists the 1201 code for gliders.
There is an internal FAA Change Notice Document dated May 2011 to
change AIM, FARs and 7110.65 plus other FAA Documnets to the 1202
code, effective 9 Feb 2012.
T
Old February 9th 12, 02:11 AM posted to rec.aviation.soaring
Dave Nadler
Thanks - Does this mean that the effective date
is really 7-March (and not 9-February as briefed) ?
Best Regards, Dave
Old February 9th 12, 02:29 AM posted to rec.aviation.soaring
Dixie Sierra
Best Regards, Dave
I contacted ATCT in my local area and they told me 3/7.
who knows?.. all politics is local and I guess squawk codes are too
Old February 9th 12, 02:34 AM posted to rec.aviation.soaring
Frank Whiteley
Best Regards, Dave
http://www.faa.gov/documentLibrary/m.../N7110.577.pdf
New Transponder Code (1202) for Gliders (Effective Feb 9, 2012) CLewis95 Soaring 14 May 26th 11 12:09 AM
New Transponder Code (1202) for Gliders (Effective Feb 9, 2012) 5Z Soaring 2 May 26th 11 12:02 AM
Stuck ident Bob Noel[_6_] Owning 4 September 14th 09 04:41 AM
New Airport Ident (and I don't believe it) Montblack Piloting 0 April 13th 06 03:19 AM
Transponder Information Requested JohnD Soaring 1 January 6th 04 08:34 PM
