Violating Airspace with GPS
Old October 30th 03, 08:08 PM
John Bell
Default Violating Airspace with GPS
It appears that a lot of pilots are violating airspace even with GPS on
board.
I would like to hear some feedback as to how pilots are violating airspace
with GPS. I address this in my online book, www.cockpitgps.com. I have my
hypothesis, but I would like to hear your experience or scenarios that you
have heard involving this issue.
Also of interest is how you might be using GPS to successfully avoid
airspace violations.
Other hypothesis are also welcome.
John Bell
www.cockpitgps.com
Here is my hypothesis:
I have already mentioned in my discussion of database currency that you
should set up a routing around any airspace and check it with a current
chart before flight. Even with a current database, it is possible for the
GPS to get you into trouble with airspaces.
Aviation receivers can be setup to display airspace boundaries and to give
warnings before entering certain airspace classifications such as category B
airspace. These warnings can be a great benefit or a nuisance depending on
the type of flying that you are doing. Thus, most receivers allow you to
turn them on or off. Additionally, which boundaries will display and at what
point of zooming out they will disappear can be set. The ability to make
these settings is a good feature and I would not want to see this changed.
However, it is possible to have the GPS not display or not warn of an
impending airspace violation if you have the GPS set up incorrectly for the
mission.
Even if the airspace boundary is displayed, it is often difficult to decide
what boundary a given line applies to. On the Garmin aviation receivers it
is possible to cursor over the point to get a description. On a handheld GPS
just press the rocker pad up, down, left, or right to start moving the
cursor. On the GPS 400 and 500 series, press in on the knob and then start
moving the cursor. Move the cursor to highlight the line and press the ENTER
button to get information on the airspace. This is a great feature at the
planning stage and is occasionally useful in flight. When you have
preplanned the route and have a route line, the context of the border is
obvious. However, I think that it is possible to confuse borders and violate
airspace without first creating a route using a chart before flight.
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 03:29 AM
most of eastern Massachussetts airspace closed in July Christopher C. Stacy Instrument Flight Rules 29 June 19th 04 01:47 AM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 07:12 PM
Help - I busted into the Class B SEATAC airspace last night, does anyone have any advice ? steve mew Piloting 38 October 28th 03 07:08 PM
FA: Congested Airspace: A Pilot's Guide The Ink Company Aviation Marketplace 0 August 10th 03 06:51 PM
