How do I download flight trace with Erixx GPS recorder?
Old May 31st 12, 03:39 PM posted to rec.aviation.soaring
Scott Alexander[_2_]
Default How do I download flight trace with Erixx GPS recorder?
Anybody familiar with this brand? The methods I'm trying are not
working
Any suggestions would be much appreciated.
SA
Old May 31st 12, 04:15 PM posted to rec.aviation.soaring
Max Kellermann
working
XCSoar can download flights from IMI ERIXX. Thankfully, IMI donated
one device to us XCSoar developers for driver development.
Max
Old May 31st 12, 04:22 PM posted to rec.aviation.soaring
Tim Taylor
On May 31, 7:39*am, Scott Alexander
Anybody familiar with this brand? *The methods I'm trying are not
working
SA
Scott,
You need to provide details for the methods you have tried. We will
assume you have used all the correct software, baud rates and loaded
the correct drivers on your Computer or PDA. Also what you are seeing/
hearing on connection will be helpful in diagnosing the problem. Are
you getting the correct beeps when connected?
Old May 31st 12, 04:40 PM posted to rec.aviation.soaring
I used Glide Navigator 2 for the entire flight. It worked great. When
I finished the flight, I pressed "quit program" and then for some
reason it did not ask "do you want to transfer your flight log" like
it has with before with a Cambridge model 10.
XCSoar is downloaded on the PDA as well, but I cannot figure out how
to download the flight trace with it. I also ran a USB cable from the
GPS to my laptop to see if it could be done that way and the laptop
would not recognize the GPS (despite the fact that when I plugged in
the cable from the laptop it provided power to the GPs and turned the
green light on.)
Any thoughts?
Old May 31st 12, 05:52 PM posted to rec.aviation.soaring
Tim Taylor
On May 31, 8:40*am, Scott Alexander
to download the flight trace with it. *I also ran a USB cable from the
green light on.)
Any thoughts?
Any logger will need specific drivers and software. If you have the
latest version of XCSoar then there should be a download function with
specific settings for the logger. Max will be better at helping with
that.
For the PC you will need to download drivers and the software from:
http://www.imi-gliding.com/index.php...t&id=4&lang=en
Then you can download the files.
Old May 31st 12, 07:34 PM posted to rec.aviation.soaring
Cats
On May 31, 4:52*pm, Tim Taylor wrote:
snip
snip
Not necessarily true. The Ew MicroRecorder plugs in with a standard
USB cable and automatically appears as a removeable HDD in 'My
Computer' - at least it does on Windows PCs, unless they have an ark-
ware version. The same is true of the Nano, but not of the Erixx.
Old June 1st 12, 01:43 AM posted to rec.aviation.soaring
Tim Mara
Did you use the software that comes with the logger? it's really one of the
simplest loggers to download with USB cable supplied and the software..or
are you trying to display the flight ? even simpler if you have seeyou or
any flight review software.call me and I can walk you through in a few
minutes, My # is on my website www.wingsandwheels.com
tim
"Scott Alexander" wrote in message
working
SA
Old June 1st 12, 08:24 PM posted to rec.aviation.soaring
Wojciech Scigala
working
The easiest method is to use SeeYou and connect to IMI via RJ45 cable
(FAI-standard RJ45, same as Volkslogger).
WojtuÅ›
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 09:31 PM
Erixx GPS Flight Recorder - Feedback? Paul Remde Soaring 1 December 23rd 08 01:16 AM
Erixx flight recorder - opinions? Wojciech Scigala Soaring 2 November 3rd 08 03:27 PM
OLC flight trace page Brad[_2_] Soaring 1 October 20th 08 06:12 PM
Flight download Steve Freeman Soaring 8 June 19th 07 11:01 PM
