Painting Your Restored Aircraft
Old January 28th 04, 05:29 PM
jls
Default Painting Your Restored Aircraft
You have to take the wings off, don't you? Anybody shoot an aircraft with
paint from under the wings or under the belly? Just wondering out loud
here.
Old January 28th 04, 07:49 PM
Orval Fairbairn
here.
You have to use a pressure pot/gun combination. It is done all the time.
Old January 28th 04, 08:19 PM
Bela P. Havasreti
On Wed, 28 Jan 2004 11:29:13 -0500, " jls"
here.
Yes. It helps to get the aircraft up off of the ground some (in my
case, raise the tail on a taildragger and set it on a medium sized
ladder). Use a crawler to slide around underneath while painting.
You'll want to use an orientation insensitive spray gun (I don't think
any of them will shoot/spray "up-side down", but some work better than
others). For instance, a gravity-feed gun might not work well while
laying on your back, trying to spray the belly
I use an HVLP conversion gun while priming, but I like to use a
pressure pot with a quality remote Binks-type "high pressure" gun
for shooting top-coats.
Bela P. Havasreti
Old January 29th 04, 04:15 AM
Plumb Bob
"Bela P. Havasreti" wrote in message
Take a look at the 3M PPS system... can convert a gravity gun to spray at
any angle, even up.
Old January 29th 04, 05:32 AM
Bela P. Havasreti
any angle, even up.
Will do!
Thanks for the tip.
Bela P. Havasreti
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 05:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
