Measured current draw, PowerFlarm Brick
Old July 15th 12, 10:48 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default Measured current draw, PowerFlarm Brick
PF manual does not list typical power consumption. Because PowerFlarm
can supply power to other devices, this is a variable figure. The
manual says only "up to 1.2 Watts", or 1 amp at 12V. That's rather a
lot, so I decided to check. My PF brick is connected to a Butterfly
57mm flarm panel display and ClearNav (via serial port). I measure
170 mA at 12.4 VDC, which is reassuringly small.
-Evan Ludeman / T8
Old July 15th 12, 10:55 PM posted to rec.aviation.soaring
That would be 100mA at 12V.
Bart
Old July 15th 12, 11:07 PM posted to rec.aviation.soaring
Darryl Ramm
Bart
Did you make independent measurements?, Based on the quoted measurement and assuming ideal power behavior it would be ~165mA at 12.0 VDC.
Actual power consumption will depend to some extent on the environment (e.g. other equipped gliders nearby etc.).
Darryl
Old July 15th 12, 11:15 PM posted to rec.aviation.soaring
Bart[_4_]
On Jul 15, 2:07*pm, Darryl Ramm wrote:
> can supply power to other devices, this is a variable figure. *The
Me? I have not measured anything. I only stated that 1.2W at 12V
requires current draw of 100mA, not 1A.
Bart
Old July 16th 12, 01:03 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
PF manual does not list typical power consumption. *Because PowerFlarm
Bart
You're right, of course.
I got busy reading about a few hundred milliamps for this in, 500 for
that (at +3 or +5V, not 12) and slipped the decimal. Oops.
In any case, 170 mA is a pretty good measurement. That's sitting in
my driveway with GPS and flarm transmission active, no threats.
-Evan / T8
PowerFlarm Brick - Can it send GPS sentences to SN10B? WaltWX[_2_] Soaring 11 June 17th 12 06:33 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
PowerFLARM 'brick' progress? Frank Paynter[_2_] Soaring 5 November 13th 11 08:28 PM
Display for PowerFLARM brick Andy[_1_] Soaring 4 May 10th 11 03:32 PM
TruTrak ADI current draw Hellman Soaring 7 May 29th 08 06:37 AM
