Jabiru 5100 - any experiences yet?
Old February 5th 04, 05:14 PM
Andreas Maurer
Default Jabiru 5100 - any experiences yet?
Hi gentlemen,
subject says it all. Are there already any experiences with the new
Jabiru 5100 engine? So far the only information I have found was the
one on the Jabiru website.
Bye
Andreas
Old February 5th 04, 06:58 PM
jls
"Andreas Maurer" wrote in message
Hi gentlemen,
Bye
Andreas
If I wanted a REAL 180HP aircraft engine I'd go with an XP360 from Mattituck
or Titan kit from ECI or something like that, particularly since the Jab
costs 22k and has 4 too many cylinders to have to keep up and revs way too
high. Can we say glorified Beetle engine here?:
http://www.usjabiru.com/jabiru_5100.htm
Old February 5th 04, 07:05 PM
jls
Hi gentlemen,
Bye
Andreas
Old February 5th 04, 10:17 PM
Mike Borgelt
On Thu, 05 Feb 2004 17:14:07 +0100, Andreas Maurer
Hi gentlemen,
Bye
Andreas
A good friend is finishing an RV7A with that engine in it. May be
only a few weeks away from flying.
I know that Jabiru bought an RV6 for testing and they have some
several hundred hours on it. I've seen it flying.
Eight cylinders may have some advantages over 4. The smaller cylinders
likely will have better combustion and if you lose one the engine may
still deliver useful power without running too rough. Guess how they
know.
Mike Borgelt
Old February 6th 04, 01:01 AM
CW9371
know.
Mike Borgelt
also gives u a smoother running engine
Old February 6th 04, 02:00 AM
Andreas Maurer
On Thu, 5 Feb 2004 13:05:21 -0500, " jls"
More or less Beettle..
The main cause why I'm interested in the 5100 is its weight - 117 kg
dry weight is a lot better than anything else around that I'm aware
of. It is also pretty narrow, making it possible to use a pointed
cowling whith its better aerodynamics. The O360 is a monster compared
to the 5100.
One more handicap is that I'm in Germany, making it problematic to use
US engine conversions that have not been licensed by the German
authorities.
But thx a lot anyway for the hint...
Bye
Andreas
Old February 6th 04, 02:44 AM
Richard Lamb
to the 5100.
authorities.
Bye
Andreas
260 pounds?
That's a pretty respectable weight -
unless
external oil tank?
It that with accessories like starter and alternator?
Does it have a vacuum pump pad?
It's air cooled, isn't it? No radiator.
Still,
An IO-360 runs 330 pounds without accessories...
Old February 6th 04, 04:17 AM
Bill Daniels
"Richard Lamb" wrote in message
Mattituck
Jab
too
to the 5100.
authorities.
Bye
Andreas
260 pounds?
unless
external oil tank?
Still,
Ever tried to pick up an O-360 crankshaft? I tried, then I got some help.
The O-360 "Lycoming Paint Shaker" has four massive 5 1/2" diameter pistons
that pound that crank mercilessly - it HAS to be heavy. A crank in a flat
8, by comparison, has the power impulses spread over 4 whacks per revolution
so it can be lighter. On the downside, the flat 8 has higher internal
friction so the SFC will be worse.
Bill Daniels
Old February 6th 04, 04:41 PM
Andreas Maurer
On Fri, 06 Feb 2004 01:44:29 GMT, Richard Lamb
260 pounds?
unless
external oil tank?
This is the toy I'm talking about....
http://www.jabiru.net.au/engines/8cylin.html
I really like the compact size and the low weight, although the fuel
coonsumption could be a lot better...
The 360 (and 320) is a monstrum and I'm not considering it for my
planned aircraft due to sheer size and weight.
Another engine that looks pretty good is the new Thielert Diesel
engine
http://www.centurion-engines.com/c17/c17_start.htm
...., but its weight and extreme comlexity are less than perfect,
although performance and fuel consumption are very good.
Bye
Andreas
Old February 7th 04, 12:49 AM
Paul Lee
Richard Lamb wrote in message ...
260 pounds?
unless
external oil tank?
Still,
You can get those details on their website
BTW - the Jab 8 can burn autogas with no problem.
The somewhat higher RPM is also not a problem, just get the
right prop for it.
I considered the Jab engine for my canard project, and even put a
deposit, but it came out too late for me. And also the original claims
were 200hp but now it is down to 180hp. So I went with a 220hp
6 cyl Franklin - about the same weight as Lyc IO-360 but a lot smoother.
The biggest beef I have with Lyc 360 is the vibration - essentially a
giant VW engine. Cont. IO360 is a 6 but considerably heavier than
Franklin.
Paul Lee, SQ2000 canard project: http://www.abri.com/sq2000
Jabiru V Rotax reliability? Joe Home Built 11 September 5th 03 12:09 PM
