Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts.
Old January 19th 04, 09:35 PM
Howard Berkowitz
Default Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts.
On Mon, 19 Jan 2004 00:46:41 GMT, "LawsonE" wrote:
All I've been pointing out is that there is no "absolute" verdict you
can
give on this subject since it would depend on what was hit, where, and
with
what. The worst case would be shooting holes in avionics, or causing
some
kind of engine trouble that might lead to further destruction. A
slightly
less dangerous case (I'm guessing) would be where a bullet hit the
forward
windscreen, punching a hole in it. Anyone who wants to tell me that the
structural integrity of any material with a hole punched in it is the
same
as the non-damaged material, is full of it. No-one has cited a test or
incident where a bullet was shot into the front windscreen while the
plane
was travelling 500mph, and even if there are such incidents, the
conditions
are so extreme that one or two examples probably don't say anything
about
the "average" case.
There are airplanes, including 747s, that have continued to fly quite
nicely, if rather noisily in the cockpit, after striking Canada geese
with the windscreens, cracking them.
Horrible mental image of a bird reaching up and goosing a 747...
Aircraft windscreens are a)
over-designed for bird strikes, b) made of numerous layers laminated
with the same sort of stuff used in car windshields, and c) backed up
by cockpit/cabin pressurization systems with considerably more
capacity than they use in normal flight.
I might also point out that the windscreen in front of the captain is
entirely separate from the windscreen in front of the first officer,
so damage on one side won't affect the other side. The side
windscreens are also separate, as are the eyebrow windscreens, where
present. Since forward vision is not required to land an airplane,
particularly a highly-automated airliner, damage to one windscreen is
not any big deal.
Mary, are there any provisions to protect the pilot on the damaged from
at least the annoyance of wind? If nothing else, it's going to be COLD.
I freely concede that a windscreen with a bullet hole in it is not the
same as an undamaged windscreen, but the undamaged windscreen is
sufficiently strong that the damage from the bullet hole is not enough
to render the damaged windscreen useless or hazardous.
Old January 19th 04, 10:21 PM
Newps
The RJ's that everybody is flying now crack windshields like they are
going out of style. Just last week we had one land here so spider
webbed that the captain could see nothing out his side. They apparently
are very simple to replace as they were on the road again in less than
24 hours.
Old January 19th 04, 11:59 PM
Mary Shafer
On Mon, 19 Jan 2004 15:35:56 -0500, Howard Berkowitz
Usually the windows don't break. They just crack, admitting pureed
bird*, if present. (Eeeuuugh!) In such cases, cockpit heat is good
enough to keep the crew warm.
I think, but don't know and haven't looked, that the rules require
landing soon if the windshield is actually broken out, whereas the
rules allow the flight to continue if it's only cracked. In the only
case I have first-hand knowledge of, they hit the goose and cracked
the windshield while climbing out from San Francisco and continued to
London Heathrow.
*The usual cause of windshield cracking in flight, although
temperature stress can cause it, as can mechanical stress. The X-15
had one of each of the latter two, for example. Like airliners,
research aircraft rarely have any sort of battle damage, so I don't
have any bullet strike accounts to relay for Dryden aircraft.
ObMilitaryAircraft: The convertible F-18 that Bill Dana flew was the
result of a canopy latch problem, not a bird strike or battle damage.
I know a guy who lost a T-38 canopy in flight, again from a mechanical
problem. In both cases, it was pretty bad, cold and windy and too
noisy to hear anyone on the radios. The checklist says something like
crank your seat all the way down, tighten your chin strap and O2 mask,
announce the situation on the relevant frequencies, and land or trap.
In the case of a bird strike on a high-performance airplane with
canopy, the problem is that the canopy usually doesn't hang around
long enough to ward off the subsequent birds, and they smack into the
front-seat pilot's head and face. This is one of the important
reasons why pilots are supposed to keep their clear visors down and
locked.
Mary
Mary Shafer Retired aerospace research engineer
Old January 20th 04, 12:01 AM
Mary Shafer
24 hours.
It took 8 hours to turn a 747 that struck a snow goose on the way to
Heathrow about a decade and a half, maybe two decades, ago. And this
included getting the replacement windshield in from Washington.
However, the bird strike was reported while the airplane was still in
the air, so it may well have taken more time, time that didn't show up
in the delay.
When we boarded the airplane, it was impossible to tell that anything
had gone amiss. The cockpit didn't even smell of goose entrails,
although what usually happens in such strikes is that the goose is
pureed through the cracks in the windshield. Eeeuuugh.
Mary
Old January 20th 04, 07:52 AM
fudog50
Not bad Mary, here is a little more about aircraft windshields and the
requirements for replacing them, and the maintenance effort. Ok, they
are laminated, and each manufacturer puts out specs on how much damage
(layers) and where the damage can occur. If the damage is in the
windshield heat section, or is in a certain structurally unsafe
section, or obscures the pilots scan (safety of flight issues) it's
outta there. It is a relatively easy replacement, the only real issues
are the hundreds of screws, the lengths, making sure you get the right
ones back in the right spot, and the sealant. If it is cold weather
obviously it's gonna take longer for it to seal. It takes additional
time to find hangar space, move assetts, do a respot if it is cold out
and you need 55 deg for a good cure, otherwise you can do it out on
the line. Then you gotta do a pressure check to check for leaks which
requires pressurization of the whole aircraft (neg) on the deck. It's
a requirement for the Navy, not sure about the civvies. I've heard
knuckleheads say, "why do a pressure check? we''ll know if it leaks
when we get to altitude." Usually we take an aircraft off the schedule
for at least 12 hours, (6-12 hours given for cure time, about 2-4
hours for maintenance and the pressure check). Anything less is a
calculable risk made with all professional entities, (ops and
maintenance) dictated by a flight schedule driven by a profit, or
mission accomplishment. Next time you see an aircraft delayed for only
8 hours for a windshield replacement, the only thing that could make
it that fast would be a sealant that has about a less than 2-4 hour
cure time. Wish we could get our hands on some with a milspec.
On Mon, 19 Jan 2004 14:59:45 -0800, Mary Shafer
London Heathrow.
locked.
Mary
Old January 20th 04, 07:56 AM
fudog50
Pureed through the windshield? Where on earth did you get that?
"usually" what happens is that only a few layers of the laminate are
destroyed. "Rarely" does anything make it through all layers and
"Rarely" would any goose puree the entrails into the cockpit. LOL
On Mon, 19 Jan 2004 15:01:45 -0800, Mary Shafer
24 hours.
in the delay.
Mary
Old January 20th 04, 12:55 PM
Paul Stevens
Our shop has done replacements where we told flight ops that the
plane needed to sit for 24 hours for the sealer to cure, but they
flew the plane in less than 12 hours. We haven't had any reports
of pressure leaks, but they did do a lot of complaining about how
the sealer was streaked down the sides of the fuselage, after the
flight.
Paul Stevens
Bill 'n' Opus in 2004
Old January 20th 04, 02:18 PM
Morton Davis
COLD.
London Heathrow.
locked.
Mary
"fudog50" wrote in message
Got two words for you: RETURN KEY. Learn to use it to create paragraphs.
Otherwise, looks good.
-*MORT*-
Old January 21st 04, 12:13 AM
Howard Berkowitz
In article , fudog50
Is there technology that would just admit pate?
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. B2431 Military Aviation 17 January 21st 04 12:13 AM
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. Todd Pattist Piloting 2 January 15th 04 05:55 PM
Can you say: Payne Stewart ? - Explosive Decompression? Try ityourself, numbnuts. G.R. Patterson III Military Aviation 0 January 15th 04 12:36 AM
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. S Narayan General Aviation 2 January 14th 04 11:22 PM
Can you say: Payne Stewart ? - Explosive Decompression? Try it yourself, numbnuts. S Narayan Piloting 2 January 14th 04 11:22 PM
