Pylon mounted wings superior?
Old February 4th 14, 04:28 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Default Pylon mounted wings superior?
After some back and forth discussion, it seems pylon-mounted wings could have a lot of potential for sailplanes.
WRT aerodynamics, they make a laminar upper wing and much more extensive laminar flow on the fuselage possible.
Structurally, notably yaw forces might be problematic (ground-loop), but nothing impossibly difficult. With the possibility of a mid-wing one can remove the heavy spar stubs and control connections and also reduce complexity a lot, notably for drag brakes and flaps.
A few designs from the past come to mind. SH had a pylon-wing on an experimental Cirrus and it reportedly flew well. The Streifeneder Albatross and the Akaflieg München Mü31 are heading in that direction, but are only halfway to the advantages of a full pylon wing.
So why don't we see pylon-mounted wings on modern sailplanes? I can see why not in production ships from the established factories; any radical change demands a steep and risky learning curve. But for new factories and/or experimental ships, at first glance there seems a lot of potential.
Any major issues with pylon wings that we've overlooked?
Old February 4th 14, 05:41 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Eric Raymond has been taking advantage of this for years. Both of the Sunseeker aircraft have pylon mounted wings. http://www.solar-flight.com/
Craig
7Q
Old February 4th 14, 06:11 PM posted to rec.aviation.soaring
JS
Ah, finally the value of the sleek Slingsby T21 "Rhone-Moose" will go up.
Old February 4th 14, 06:15 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Tuesday, February 4, 2014 11:11:33 AM UTC-6, JS wrote:
Ah, finally the value of the sleek Slingsby T21 "Rhone-Moose" will go up. Jim
Only if you also install winglets, Jim!
Steve
Old February 4th 14, 06:25 PM posted to rec.aviation.soaring
John Carlyle
Or we could remove the engines from a PBY-5a Catalina and turn the pontoons up to get (nearly) the same effect.
-John, Q3
Old February 4th 14, 06:34 PM posted to rec.aviation.soaring
Richard[_9_]
Craig
7Q
The main reason Eric has pylon mounted wings and a T tail is that the solar cells can not be partially shaded it causes problems.
Richard
Craggy Aero
Old February 4th 14, 07:04 PM posted to rec.aviation.soaring
kirk.stant
Steve
And a couple of air extractors...
Kirk
Old February 4th 14, 07:32 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Kirk
Maybe some de-turbulators....
Old February 4th 14, 10:53 PM posted to rec.aviation.soaring
It seems it would make the structure more complex and heavier. I would guess it also would cost more to build a pylon wing glider. Shoulder wings with smooth integral wing root fillets (ASW-15 for example) should also be more efficient than simply mating the wing end on to the side of the fuselage but Schleicher seemed to give this up as not worth the effort when they moved to the ASW-19 (mid mounted wing with a more vestigial fillet).
One of the interesting things about glider design is that, even for open class, it's not really a free for all. The design has to comply with national airworthiness requirements and have acceptable flying characteristics for the average pilot. Compare this to an Unlimited Reno racer for example. I remember what Gerhard Waibel said about the ASW-12 in hindsight. It was something about learning how all new, hot gliders will become older gliders flown by less than top rank pilots eventually and you have to take that into consideration even when you're trying to make a world championship contender..
Old February 5th 14, 01:40 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
potential.
One. You need a fair pylon height to avoid interference drag in the gap
between the top of the fuselage and the wing's lower surface. I'd say
interference drag is relatively high on the Sunseeker shown he
However I'm not an aerodynamics expert and have no idea what the optimum
height sound be except that its unlikely to be less than 10-15% of the
wing chord, think of the Wien for this pylon height, and that its one
problem the Ku-4 Austria didn't suffer from.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Cartoons, pt 5 - Superior.jpg (1/1) Mitchell Holman[_3_] Aviation Photos 1 July 30th 09 02:41 PM
Honda Biz Jet With Wing Pylon Mounted Engines ? Robert11 Piloting 6 September 8th 07 08:12 AM
Pylon 8 problem gatt Piloting 8 June 26th 06 11:33 PM
Fin Mounted TE Prob vs fuselage mounted TE prob [email protected] Soaring 8 June 4th 05 11:39 PM
AND THE KIS CRUISER ROUNDS THE PYLON... Paul Folbrecht Home Built 38 January 18th 05 05:29 AM
