ILS reception question
Old June 10th 04, 09:56 PM
gatt
Default ILS reception question
Anybody ever seen intermittent ILS localizer reception during multiple
missed approaches?
What causes that?
Was doing ILS localizer and back course approaches at McNary (Salem) last
night in solid IMC. That was a blast, until the third approach. We hit the
intersection at the right altitude, but couldn't get a solid enough needle
reading to complete the approach.
That's kind of a rush, when you lose radio navigation and you're in the
middle of a freakin' cloud. Seattle Center vectored us to VFR and all was
fine, but my instructor said she'd seen that happen at that particular
approach maybe a half dozen times, in as many airplanes. We've had NO
trouble with reception in that particular aircraft anywhere else, so it
looks like a transmission problem. What causes that, to whom can we report
it who will take it seriously, and is this common?
The flight home was pure Kodak. Vectored us to 6,000 feet which was the
overcast top and found outselves right on top of that layer with another
layer over us, and the setting sun right in between.
-c
Old June 10th 04, 10:29 PM
EDR
In article , gatt
missed approaches?
What causes that?
Not sure about the localizer, but glideslope can be affected. I will
have to pull out my copy of TERPS to check.
Was there an aircraft parked somewhere in the runway environment
(beyond the hold-short line) between you and the the ILS antennas?
The glideslope signal is reflected off the flat ground between the
antenna and the runway threshhold. Hold-short lines on the taxiways are
placed far enough back from the runway that an aircraft in the runup
area will not interfer with the glideslope signal.
Old June 11th 04, 12:31 AM
gatt
"EDR" wrote in message news:100620041637580530%
Shouldn't have been. It was right after tower closed for the evening and
the only other aircraft reporting was a National Guard helicopter taxiing
for closed traffic (IFR minimums...low clouds/fog) We had the glidescope,
just not the localizer needle. And we had it on the first approach as well
as on the back course loud and clear. Was just that one time, and it came
around right as I called for missed approach, but that wasn't until I'd
passed the outer marker (I was already climbing out by then. )
We were there. Followed the needle out, did the procedure turn, came back
around, picked up the needle again and the right before the outer marker it
just blipped out and we got nothing.
Given the IMC conditions we didn't ask to be vectored to try again, but it
was a great learning experience anyway.
-c
Old June 11th 04, 01:09 AM
EDR
In article , gatt
I wonder if the helicopter was doing its approach in the path of the
localizer antenna?
-c
Old June 11th 04, 01:49 AM
gatt
"EDR" wrote in message news:100620041919505739%
localizer antenna?
That's very possible. He was doing closed traffic, but for a helicopter in
that kind of weather it was probably a very tight pattern which would
explain how the needle would come alive and then just as suddenly go dead.
-c
Old June 11th 04, 03:05 AM
BTIZ
I once flew a Piper Arrow.. that the ILS would be intermittent depending on
gear configuration.. or loose it in a turn.. we figured the nose gear was
blocking a belly antenna.. but it was not consistent
BT
"gatt" wrote in message
missed approaches?
What causes that?
report
-c
Old June 11th 04, 03:19 AM
Roy Smith
Didn't have to be an aircraft. Could have been anything big and metal.
Like a truck. Or a tractor mowing the grass (but I suspect they don't
mow the grass late at night). But why are you so sure it wasn't the
chopper?
You might want to file a NASA report if you can't find anybody else
interested in listening.
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 10:32 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 10:40 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 07:05 PM
