Advancement of prop blade in flight, new information
Old August 16th 04, 06:37 PM
Corky Scott
Default Advancement of prop blade in flight, new information
Sorry, I got my information wrong when I stated that a three bladed
prop advanced 15 inches during each revolution at 200 mph.
I now have the article in front of me and the exact quote is as
follows: "At 200 mph and 2,800 rpm, the blades on my three-plade prop
follow three distinct helical paths through the air, and each blade is
25" ahead of the previous blade at the same point of rotation."
I repeat that I am not a prop engineer nor do I have any formal
training in aerodynamics but it appears to me that by advancing 25"
during it's revolution, the affect of one blade might have upon the
next one would seem to be pretty inconsequential.
Corky Scott
Old August 16th 04, 07:16 PM
AJW
Corky Scott
For what it's worth, at 150 kts and 2500 RPM means the airplane advances about
6 feet per prop rev. A two bladed prop means each balde is in air 3 feet ahead
of the prior blade.
Old August 16th 04, 11:04 PM
Roger Long
If you look at a diagram of the streamlines around a wing, which is all a
prop is, you'll see that the velocity and direction of the air is changed a
surprising distance above and behind the wing. One of your prop blade tips
would be like a wing flying two feet above and behind another. The effect
at this distance would not be significant but would exist.
However, the same prop climbing out at 90 mph and 2800 RPM would put each
blade only 11.15 inches "above" the preceding. This is close enough that
each blade will encounter air that already has some component of motion to
the rear. This reduces the change in velocity (lift) that the blade can
impart.
The three blade prop will be less efficient per unit of area than the two
blade where it counts, near Vx with trees in the windshield. Given a
limitation on length however, the extra blade area of the three blader can
easily offset the efficiency loss by a substantial margin.
Another factor in the efficiency equation is the tips. The tip losses and
vortexes are a big factor in wings which is why there is such emphasis on
making tips small (high aspect ratio) and things like winglets. A three
blade prop has an extra tip which will effect the effeciency without any
help from the blades ahead.
Roger Long
"Corky Scott" wrote in message
Corky Scott
Old August 16th 04, 11:35 PM
DanH
AJW wrote:
[snip]
of the prior blade.
That's the same number I came up with, but that assumes there's a
one-to-one ratio between engine RPM and prop RPM. Is that true of all
single engine piston aircraft? I'm obviously not an AC mechanic, but I
thought I could see a reduction gear in the cowl.
DanH
Old August 17th 04, 12:13 AM
AJW
AJW wrote:
[snip]
about
ahead
of the prior blade.
I don't know of a SEL airplane in general use that uses reduction gearing
between the shaft and the prop, Dan.
Old August 17th 04, 05:59 AM
Mike Rapoport
Any airplane with a "G" in its engine designation.
MU-2
"AJW" wrote in message
AJW wrote:
[snip]
advances
about
feet
ahead
of the prior blade.
Old August 17th 04, 10:20 AM
Thomas Borchert
Ajw,
All Thielert Centurion driven aircraft - way over 100 and counting.
Thomas Borchert (EDDH)
Old August 17th 04, 11:14 AM
Dylan Smith
Many hundreds of examples of Europa aircraft. My friend's Europa runs
the 4-cylinder, opposed, liquid cooled 914S engine at something like
5400RPM in cruise. I think the prop turns less than half that RPM.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old August 17th 04, 11:22 AM
Dylan Smith
Anecdotally, I'd say that the extra blade does easily offset the losses.
You see quite a few glider tugs (lower powered ones especially) like the
Ralleye with a 4-blade prop to improve climb performance (and reduce
noise due to shorter blades)
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 11:20 PM
A question only a newbie would ask Peter Duniho Piloting 68 August 19th 04 12:54 AM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 03:54 AM
IVO props... comments.. Dave S Home Built 16 December 7th 03 12:43 AM
