Manifold Pressure at Rest
Old August 18th 04, 12:48 AM
Andrew Gideon
Default Manifold Pressure at Rest
Did I misunderstand my reading on the subject, or should the Manifold
Pressure on an engine that's off be the local atmospheric pressure?
I've just noticed that this is not the case in my little R182.
- Andrew
Old August 18th 04, 01:26 AM
Dave S
Should be the same value if the engine is not operating and the gauge is
correctly calibrated. I would suspect the gauge is out of calibration.
Dave
- Andrew
Old August 18th 04, 01:31 AM
Dave S
Let me amend my answer to be "same value if the engine is not operating,
the gague is correctly calibrated and you are AT SEA LEVEL".
Remember that local altimeter settings are corrected for sea level when
you are at a locale that is at elevation. 29.92" setting in Denver is a
"corrected reading" for what the pressure would be if you were at sea
level. So, ballpark.. the value is 1" per thousand (without digging out
reference material) pressure change/altitude. Denver on a standard day
(setting 29.92") should have a manifold pressure gauge reading (5000
ft/5" less) just under 25" when the engine is off.
Sorry for my initial error.
I'm sure if there are others, they will be quickly pointed out.
Dave
Dave
- Andrew
Old August 18th 04, 03:28 AM
John Gaquin
Where are you?
online.com...
- Andrew
Old August 18th 04, 03:41 AM
Andrew Gideon
John Gaquin wrote:
Where are you?
I assume you're answered by: Less than 200' above sea level.
- Andrew
Old August 18th 04, 05:02 AM
BTIZ
at less than 200ft MSL, then the MP indicator with the engine at rest (and
sitting on the ground) should read the approximate value of the barometric
pressure or about 30in
Out here (2200MSL) the MP indicator would read about 2 inches or more lower
or about 28in (or closer to 27.5in) MP before engine start
BT
online.com...
John Gaquin wrote:
Where are you?
- Andrew
Old August 18th 04, 10:49 AM
Thomas Borchert
Andrew,
Should be. Otherwise, your MP gauge might need repair. Ours is
indicating about 0.5 inches too much, so we correct our settings for
that.
Thomas Borchert (EDDH)
Old August 18th 04, 05:02 PM
Robert M. Gary
Andrew Gideon wrote in message gonline.com...
It should be the same as ambient pressure, but not necessarily the
same a altimeter setting. Altimeter setting is not pressue but some
made up number that makes the altimeter read correctly (that's
actually the definition!).
-Robert
Old August 18th 04, 05:57 PM
Thomas Borchert
Robert,
it should read the same pressure as the altimeter in the Kollsmann
window when the altimeter is set to zero feet, right?
Old August 18th 04, 06:10 PM
g n p
On Wed, 18 Aug 2004 17:57:19 +0200, Thomas Borchert
Robert,
......altimeter set to ***airfield elevation***, correct??
The old QFE vs QNH settings thing...
GNP, Socata TB-9 SX-ADE, LGTG, Greece, (grounded due to Olympics in
progress, next flight 29 September)
Special prop to increase manifold pressure Fly Owning 7 December 2nd 04 08:23 PM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 09:35 PM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 04:46 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 06:18 AM
