Detonation in a Cont. 550
Old August 26th 04, 02:02 PM
Corky Scott
Default Detonation in a Cont. 550
On Wed, 25 Aug 2004 22:17:48 -0700, Richard Riley
The #3 cyl has the piston crown pretty much gone, along with the
rings. The other pistons show significant crown damage as well. The
local A&P believes it's detonation.
I'm no expert Richard, but that kind of damage could be pre-ignition
rather than detonation.
The mags were unchanged from their original factory timing, but it
turns out they were set at 18 and 20 degrees.
One would think, with those timing settings which are conservative,
that detonation would be unlikely because they are promoting a delayed
Peak Pressure Point, which should reduce pressure and heat. It should
also reduce power a bit, but that should also mitigate against
detonation.
Corky Scott
Old August 26th 04, 04:13 PM
Tom S.
"Richard Riley" wrote in message
A friend of mine has just had a Continental 550 destroy itself. He's
asked for my advice, but all my experience is with Lycomings. If
anyone has experience with 550's and can comment, I'd be thankful.
The engine has about 60 hours since new. My friend was the pilot for
the last 4 hours or so. As he's been flying it he's been getting much
higher fuel burn than he expected - cruise lean was 18-20 GPH. He's
also seen higher oil temps than expected - 220-240.
Any ideas here? He was running it at no more than 25" and 2500 RPM.
I'd have thought all that fuel would have kept it cool.
http://www.avweb.com/news/columns/182132-1.html
Pelican's Perch #43:
Detonation Myths
Old August 28th 04, 05:33 AM
I have many questions.
Was the 550 installed in a type-certificated aircraft?
Was the 550 normally aspirated?
Was the 550 equipped with the auto-lean fuel pump? If so, was your
friend trying to lean the engine manually?
When the engine was installed, was the fuel system properly set-up
following TCM SID97-3B? BTW, this is NOT optional.
Was the ignition timing accurately set/verified when the engine was
installed? A 2 degree split on an out-of-the crate engine is not
unheard of.
Did the friend have accurate CHT indication/s? What were they in
cruise?
What % power does 25 squared equal according the power chart for the
aircraft? If no power chart exists, perhaps someone in the group
flying behind a similiar 550 install can help out.
Was the cruise fuel flow an actual measured fuel flow (a la totalizer)
or was it a metered fuel pressure gage indicating fuel flow?
Detonation to the point of destruction doesn't take an engineer to
identify it. If the #3 piston was damaged to the point that the rings
seized and a slot was burned down the side of the piston (through the
rings), it was subjected to severe/extreme detonation.
I've not taken the time to read Mr. Deakin or Mr. GAMI's treatises,
but am somewhat familiar with detonation in aircraft engines . High
power setting + high CHT + advanced ignition timing + 50-100 degrees
ROP fuel flow is worst case for detonation. Reducing power or CHT,
retarding ignition timing, and either leaning or enrichening the
mixture reduces the risk.
TC
Richard Riley
Cont A40 Prop wanted Larry Aviation Marketplace 3 November 13th 04 12:19 AM
Warp Drive 2-blade HP hub for Cont. Shawn Aviation Marketplace 0 September 9th 04 07:50 AM
Detonation in a Cont. 550 [email protected] Home Built 3 August 28th 04 05:33 AM
Detonation in a Cont. 550 [email protected] Piloting 0 August 26th 04 01:45 PM
Pulse Detonation Engines (PDE's) Eric Moore Military Aviation 32 March 29th 04 12:00 AM
