Shutting down alternators before engine shutdown
Old October 28th 04, 06:23 PM
Ali Ghorashi
Default Shutting down alternators before engine shutdown
Hello All,
The manufacturer of the alternators in the Cessna 310 that I fly requires
the pilot to turn off the alternators before engine shutdown. Failure to do
this will void the warranty on the alternators. Does anyone know of a reason
for this? I have a suspicion that it has to do with the fact that with one
engine shutdown, the alternator's field on that engine can be energized by
the other engine's alternator. This may cause problems if the battery is low
(i.e reverse bias some diodes/transistors). That's just a WAG. Any ideas?
-Ali
Old October 29th 04, 04:56 PM
Dan Thomas
"Ali Ghorashi" wrote in message ...
Hello All,
-Ali
The alternator's field current is controlled by the regulator,
and when it's on but not turning the field gets pretty much full
battery voltage. That voltage would be a bit higher than normal if the
other alternator is running, but not dangerously so. The field can
take it.
The danger, as I see it, is either that the field of the
alternator on the dead engine can get hot after a while if it's not
spinning and could burn out (the fan isn't cooling it) or that the
pilot may forget to make sure the alterators are off before starting
the engines next time. Two fields can suck up enough current to make
starting an engine that much harder.
Dan
Old October 29th 04, 11:35 PM
Ali Ghorashi
The fields cannot cause a problem during startup since the alternators are
turned on after the engine starts.
-Ali
"Dan Thomas" wrote in message
m...
Hello All,
do
reason
one
by
low
-Ali
take it.
Dan
Engines and Reliability Dylan Smith Piloting 13 June 30th 04 04:27 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Emergency Procedures RD Piloting 13 April 11th 04 09:25 PM
Shutting down engine Question Lisa Piloting 26 April 5th 04 01:53 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
