A very basic question
Old November 6th 04, 04:37 PM
Ramapriya
Default A very basic question
Hi guys,
Unlike the elevators and rudder that change an aircraft's pitch and
yaw with no other secondary effect, why does the banking of wings by
the use of ailerons not just roll an aircraft but also produces a turn
(yaw)? Logically, one would expect an aircraft to keep going straight
ahead even if the pilot banked the aircraft left or right. Where does
the turning effect come from?
Is there a website you know of that can teach me such basics, without
having to bug you?
Cheers,
Ramapriya
Old November 6th 04, 04:55 PM
The Weiss Family
having to bug you?
Cheers,
Ramapriya
Rudder most definitely adds roll as a secondary effect.
In fact, I use rudder to momentarily keep the wings level when I'm changing
maps, etc.
At low speeds, when the ailerons are not that effective, rudder can be much
more effective.
As to the aileron, think of the relative wind on the wings.
With an aileron dropped (looking like a flap), there will be increased drag.
Of course the other one goes up, but I don't think the resultant force is
equal on both wings.
Thus, yaw results.
While it seems intuitive to me, I probably don't have the best explanation,
so can anyone else elaborate?
Adam
N7966L
Beech Super III
Old November 6th 04, 05:09 PM
Stan Prevost
"Ramapriya" wrote in message
om...
having to bug you?
http://www.av8n.com/how/
Old November 6th 04, 05:41 PM
Martin X. Moleski, SJ
All aircraft are a series of compromises.
The location of empennage with respect to the wings,
the dihedral in the wings, the location of the wings with
respect to the thrust line and center of mass, the
airspeed of the maneuvers, and probably a dozen
other variables all affect what happens when one
control input is given.
When an aircraft equipped with unbiased ailerons is
banked, the downgoing aileron causes more drag
than the upward deflected aileron does. In Piper Cubs,
for example, this means that the high wing in a bank
tends to drag the nose AWAY from the direction of
the intended turn. In a left bank (right wing high,
left wing low), the nose tends to yaw to the right
because of the difference in drag. To make a
coordinated left turn, you need to step on the
left rudder to counteract the adverse yaw while
using the ailerons to bank to the left.
In other aircraft that have differential ailerlon trim,
the aileron will not go as far down as the other
aileron goes up. That solves the problem of
adverse yaw. Now we've got a semi-pure bank,
but the aircraft will tend to lose altitude and head
in the direction of the bank because of the loss
of lift due to the changed angle of attack of the
wings with respect to the relative airflow.
Take an extreme example: if you bank the
plane 90 degrees (knife-edge), the nose will
drop quite rapidly toward the ground because
the wings no longer produce lift against the tug
of gravity. The "lift" produced by the wings will
be toward the canopy and the aircraft will
tend to move in that direction.
In a less severe bank, there still is that component
moving the aircraft toward the canopy. If you
mix in a little elevator to maintain altitude in the
bank, the elevator will help to point the nose in
the direction of the turn without requiring rudder
to coordinate the nose with the bank.
There are other factors as well. In making any
motion from straight-and-level flight, there is a small
component introduced by shifting the plane of the
propellor from its equilibrium. It's a little bit like
moving a spinning wheel from its equilibrium.
The gyroscopic forces will act against the
turn 90 degrees away from the direction of the
turn. Physics profs like to show this force by
having someone stand on a turntable holding
a spinning wheel. By tipping the wheel in one
direction or another, they can make the turntable
spin this way and that.
The classic case of this gyroscopic force was found
in the WWI aircraft that used rotary engines. The
crankcase spun with the propellor (!). With all of that
spinning mass at the nose of the plane, very sharp turns
could be made in one direction, for good or for ill.
Modern planes with lighter propellors may not exhibit
this effect much, if at all.
DISCLAIMER:
I am not an aerodynamicist. I just play a lot with
RC aircraft. I know a great deal about accelerated
stalls and have photographs of the debris fields to
prove it. (
Marty
Old November 6th 04, 05:42 PM
BTIZ
drag.
Thus, yaw results.
Brian, are you stating that this yaw causes the turn?, actually this is
adverse yaw and resists the turn.
Come, lets step into my flying laboratory, the Grob 103, and we'll explore
that interesting concept called adverse yaw.
BT
Old November 6th 04, 05:47 PM
BTIZ
very basic answer..
the lift component, vertical and perpendicular to the wings, in a bank is
now pointed off to one side of straight up (relative to earth), there are
now two components to the lift vector, horizontal and vertical, the vertical
lift assists in maintaining altitude, the horizontal component works the
turning tendency.
That is why in a steep turn, more elevator back pressure is required. You
have reduced the vertical component of lift to maintain altitude by giving
some of the lift to the horizontal component. You need to increase the AOA
on the wings to make more lift, to maintain the required amount of vertical
component to maintain the altitude.
again, a very basic answer..
step into the flying laboratory for further exploration of this concept
BT
om...
Hi guys,
having to bug you?
Cheers,
Ramapriya
Old November 6th 04, 05:53 PM
James Robinson
Ramapriya wrote:
... why does the banking of wings by the use of ailerons not just
roll an aircraft but also produces a turn (yaw)?
Simply stated, when an aircraft is in level flight, the lift of the
wings works directly against gravity. When an aircraft rolls one
direction or the other, the lift of the wings rolls away from vertical,
remaining at 90 degrees to the wings. This means only part of the lift
works against gravity. The rest causes the aircraft to swing away from
straight flight. It is somewhat akin to the effect of banking on a race
track.
Old November 6th 04, 06:41 PM
jls
"James Robinson" wrote in message
track.
Fair enough. The turn is caused by the horizontal component of lift.
Old November 6th 04, 07:05 PM
kontiki
The turn occurs because as you roll into bank, the lift vector now
has a horizontal component which will pull you in the direction of
the bank. Think of a string suspending the wing straight up (the
lift vector for level flight). Now think of the string being pulled
sideways slightly as well as up. This will pull the aircaft in the
direction of the pull... or lift vector... which now has a horizontal
component.
The rudder is used to coordinate the turn only.
You could fly along level with a slight bank angle with no turn
(aka a "slip") if you applied opposite rudder... enough to counteract
the horisontal lift component. This will only work for a limited bank
angle however.
Ramapriya wrote:
Hi guys,
having to bug you?
Cheers,
Ramapriya
Old November 6th 04, 07:41 PM
Peter Duniho
om...
(yaw)?
The simple answer is that, theoretically, the ailerons act exactly as you
would think. That is, a turn is not caused by a change in bank.
A more complicated answer is that since the "center of lift" is ahead of the
"center of gravity", having the lift vector tilted to one side or the other
by bank does pull the nose of the airplane around a bit, inducing a turn.
An even more complicated answer points out that the ailerons themselves
create increased drag on the raised wing and reduced drag on the lowered
wing, which creates a yaw opposite in direction to the intended turn.
In reality, the ailerons and rudder are BOTH very necessary to accomplish an
efficient turn. Either can be used by themselves to change aircraft
heading, but neither is very effective alone in most airplanes.
As far as the elevator and rudder having "no other secondary effect", that's
not true. Pretty much every control on an airplane has a secondary effect.
Use of rudder will induce roll, for example, while use of the elevator can
induce yaw (mostly due to propeller effects).
having to bug you?
There are many. The one already provided by Stan's reply is one of my
favorites. There are also several good books on the topic, including the
FAA's own flight training manuals (available for download from their web
site somewhere, but I don't have a link handy) and a book called
"Aerodynamics for Naval Aviators".
Pete
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 08:22 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 10:40 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 06:23 PM
