pusejet
Old March 23rd 04, 08:18 AM
Håken
Default pusejet
Hi, im building my first pulsjet. I have calculated dimentions for 78
lbs ( 35 kg metric ) of thrust.
Here is the dimentions:
Exhaust pipe diameter : 5 Inch
Exhaust pipe lenght : 34.11
Combustion chamber lenght :11.34
Exhaust cone lenght :11.34
combustion chamber diameter 7.28
I am going to use argus type valves.
The plate that the valves rest against has 5 slots measuring 45X17
milimeters.
There are 4 of these plates, two of them forming a "V".
It is two of these "V"s velded to the front plate that has 2 holes
measuring
41.92X144.21 milimeters.
The angle between eatch plate of the 2 forming eatch "v" is 31 degrees
The valves are overlapping 3.4 mm of the edges in each slot cut in the
valve resting plate.
For fueling i am planning to use 3 steel tubes drilled with small
holes so the fuel can enter the combustion chamber.
These vill be located 3 inc deep in the combustion chamber.
So if anyone has some opninions on my design, ill be glad too hear.
Håken
Norway
Old March 23rd 04, 06:19 PM
Orval Fairbairn
milimeters.
measuring
Håken
Norway
WHY? A pulse jet is a major fuel hog and is useful mostly for converting
fuel into niose, not into useful thrust.
Old March 24th 04, 05:28 AM
guynoir
Most pulse jet designs I've seen spray the fuel into a diffuser ahead of
the valve.
Go to: http://www.pulse-jets.com/ for some useful information on pulse
jets. It has drawings of several different models of pulse and pressure
jet, including the Argus. They also have a fairly active moderated forum.
milimeters.
measuring
Håken
Norway
John Kimmel
I think it will be quiet around here now. So long.
Old March 24th 04, 08:31 PM
Pat Norton
Håken wrote
I have calculated dimentions for 78 lbs
The metric unit of force is the newton.
78 pounds force is ~350 N
Try the google converter, just do a 'search' for:
78 pounds force
Old March 25th 04, 04:47 AM
Regnirps
Then he should probably use poundals for the rest of us.
-- Charlie Springer
Old March 27th 04, 12:59 AM
Bruce Simpson
On Wed, 24 Mar 2004 05:28:15 GMT, guynoir
the valve.
There's also a heap of stuff at http://aardvark.co.nz/pjet/
you can contact me via http://aardvark.co.nz/contact/
