The perfect approach
Old November 26th 04, 03:17 AM
Capt.Doug
Default The perfect approach
It was a beautiful day in land that Mickey built- 76 degrees with full sun
while the northern folks got their first freezing blast of winter. We headed
off-shore over the islands of the Caribbean. I was on the second radio
talking to old friends and catching up on news from all the islands that I
don't get to visit much anymore. Caught up with some old friends on the
air-to-air frequencies as well. The flight levels were smooth and the
visibilty was excellent.
Then it came time for top of descent. This time was going to be sweet. There
was no complicated arrival procedure and there was no traffic in front of
us. We were number one. The center controller cleared us to decend from
FL330 to 11,000' at pilot's discretion.
One of the keys to good fuel economy in a jet is to stay high as long as you
can and then descend at idle thrust. I looked at our weight, and tailwind.
As I slowly pulled the throttles back to idle, the nose slowly dropped to
maintain airspeed. I switched from Mach airspeed to indicated airspeed
around FL240. I monitored the DME's ratio to the altimeter. It was holding
constant. I leveled off at 11,000' and let the airspeed bleed off to 250
KIAS. We switched to the approach controller who cleared us down to 3000'
and direct to the outer marker. The power was still at idle, the speedbreaks
were still stowed, and the approach was looking good.
I called the field in sight from 20 miles out and was cleared for the
visual. I pulled the nose up slightly to bleed the speed down to 200 KIAS
for the airport traffic area. At 1500' the slats and flaps were extended.
Then the gear and the rest of the flaps. The old-timers taught me to carry
an extra 20 knots into the flare when doing an idle-thrust landing. That
prevents you from developing an excessive sink-rate which prevents the gear
from going through the wing.
I bled off the extra airspeed and more in the flare. The touchdown was
sweet. There was just a hint of a bunny-hop before the ground-spoilers
popped, but the runway is so bumpy that the passengers probably didn't
notice. Without moving the throttles from idle, I popped the reversers and
let it roll to the end of the runway. We rolled onto the taxiway without
using the brakes. It was a perfect idle-thrust approach from top-of-descent
to the gate.
I spent the rest of the day sitting with my crew at a bar on the beach
enjoying the little things in life. Over the bar was a television. The folks
on the television were surrounded by snow. I bet their day wasn't near as
perfect as mine.
D.
Old November 26th 04, 03:59 AM
Jay Beckman
"Capt.Doug" wrote in message
I assume since you refer to the "northern folks" that you are referring to
the "Land that Mickey built - SOUTH" as opposed to the "Land that Mickey
built - WEST?"
Jay
Old November 26th 04, 06:00 AM
Franklin Newton
Well done Capt Doug.
headed
There
you
speedbreaks
gear
top-of-descent
to the gate.
folks
perfect as mine.
D.
Old November 26th 04, 09:38 PM
mindenpilot
That was a cool story, Capt. Doug.
I'm just a 100 hour VFR pleasure-flyer, and I know absolutely nothing about
jets and such.
So, please continue to post this kind of cool stuff!
I find it very interesting!
Adam
N7966L
Beech Super III
Old December 3rd 04, 07:25 PM
Peter MacPherson
Great story. Must be a really cool feeling going from FL330
to touchdown at idle thrust. The company was also happy
with the fuel savings..... ; )
headed
There
you
speedbreaks
gear
top-of-descent
to the gate.
folks
perfect as mine.
D.
Old December 3rd 04, 10:01 PM
Maule Driver
That was sweet! I'd buy the good Captain a round for that one.
Thanks for the bump -- I missed it the first time around.
"Peter MacPherson" wrote in message
news:Vc2sd.137670$5K2.43770@attbi_s03...
sun
headed
I
There
of
you
tailwind.
to
holding
3000'
speedbreaks
KIAS
extended.
carry
gear
and
top-of-descent
to the gate.
folks
as
perfect as mine.
D.
Old December 4th 04, 03:13 PM
Friedrich Ostertag
Hi NG,
question to the group:
Nice story, and obviously very skilled performance, but I always
thought jets were supposed to land with about 70-80% power on, to be
prepared for a potential go-around? (Because spool-up time from idle
would be prohibitive in that case?)
thanks,
Friedrich
full sun while the northern folks got their first freezing blast of
winter. We headed
radio talking to old friends and catching up on news from all the
islands that I don't get to visit much anymore. Caught up with some
old friends on the air-to-air frequencies as well. The flight levels
were smooth and the visibilty was excellent.
sweet. There
front of us. We were number one. The center controller cleared us to
decend from FL330 to 11,000' at pilot's discretion.
long as you
tailwind. As I slowly pulled the throttles back to idle, the nose
slowly dropped to maintain airspeed. I switched from Mach airspeed
to indicated airspeed around FL240. I monitored the DME's ratio to
the altimeter. It was holding constant. I leveled off at 11,000' and
let the airspeed bleed off to 250 KIAS. We switched to the approach
controller who cleared us down to 3000' and direct to the outer
KIAS for the airport traffic area. At 1500' the slats and flaps were
extended. Then the gear and the rest of the flaps. The old-timers
taught me to carry an extra 20 knots into the flare when doing an
idle-thrust landing. That prevents you from developing an excessive
was sweet. There was just a hint of a bunny-hop before the
ground-spoilers popped, but the runway is so bumpy that the
passengers probably didn't notice. Without moving the throttles from
idle, I popped the reversers and let it roll to the end of the
runway. We rolled onto the taxiway without using the brakes. It was
to the gate.
beach enjoying the little things in life. Over the bar was a
near as perfect as mine.
D.
for personal email please remove "entfernen" from my adress
Old December 4th 04, 11:31 PM
Capt.Doug
"Friedrich Ostertag" wrote in message I always
Perhaps you are confusing RPM with thrust? The correlation is not linear.
Normally the RPM is between 70% to 80% on approach, but the thrust around
20% to 25%. You are correct that normally the engines are somewhat spooled
up to provide adequate acceleration if needed. Hence the reason I carried an
extra 20 knots of airspeed into the flare when using idle thrust.
D.
Old December 5th 04, 03:47 PM
Friedrich Ostertag
Hi Doug,
seems to be the case, as far as the figures are concerned.
linear. Normally the RPM is between 70% to 80% on approach, but the
thrust around 20% to 25%. You are correct that normally the engines
are somewhat spooled up to provide adequate acceleration if needed.
Hence the reason I carried an extra 20 knots of airspeed into the
thanks for the explanation!
regards,
Friedrich
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 04:54 AM
The perfect approach Capt.Doug Home Built 25 December 3rd 04 04:37 AM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 12:13 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
