Stiffness of finished Carbon Fiber part
Old April 7th 04, 02:24 AM
RKT
Default Stiffness of finished Carbon Fiber part
I have a finished CF sample, a common single-ply weave, that exhibits
extreme stiffness, 'thin-ness' and is very lightweight, it looks dry. I have
molded a part using a similar weave, single ply, and do not get the same
stiffness. I can easily deform the finished part with a press of the thumb.
I am not sure whether this is due to the epoxy type or my humble curing
process. I'm using Fibre Glast System 2000 and 120 minute hardener. I let
the part cure for 12 hours at 110 DegF. The instructions on the can discuss
postcure at 200 DegF and the resulting 'service temperature'.
If it is an Epoxy issue, pls describe and recommend an alternative product.
If it is a postcure issue, when does 'postcure' begin - after my 12 hour
cure cycle? - which was loosely calculated based on instructions on the can.
Any advice appreciated.
Old April 7th 04, 03:32 AM
Richard Lamb
It's not about the epoxy, but the layers.
One layer has nothing to lean on.
Two layers pull against each other.
Old April 8th 04, 02:32 PM
Checkursix
I believe that and the possibility of the way you did your lay-up. Did you
use a vacuum bag? That would compact the epoxy/CF!
VS 'Free Air' Lay-up....
Bob
"Richard Lamb" wrote in message
have
thumb.
let
discuss
product.
can.
Old April 8th 04, 03:00 PM
jls
Depending on how they are laid up, CF layups get anywhere from 150k to 800k
psi tensile strength and are a capable according to computer models of 1
million lbs. psi tensile strength. The secret is in the quality of layup
and the orientation of the fibers. Read Andy Marshall's book for details.
"Checkursix" wrote in message
Realistic Strengths of Homebuilt Carbon Fiber? BllFs6 Home Built 5 March 31st 04 06:23 PM
free carbon fiber and other aircraft items Granite Stone Home Built 1 March 30th 04 01:28 AM
Carbon Fiber - Achieving Glossy Finish w/o GelCoat RKT Home Built 7 March 8th 04 07:15 AM
Carbon fiber vs. antennas Jim Weir Home Built 8 January 2nd 04 02:40 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 05:44 AM
