Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Inside the Cowling Fire / Heat Detector?
Old May 28th 04, 07:56 AM
George Sconyers
Default Inside the Cowling Fire / Heat Detector?
Does anyone know of detector available for small aircraft (not transport
aircraft / Part 135, 121) that can be installed in the cowling(s) to detect
the presence of some condition (excessive heat, IR, etc.) that would lead to
an in-flight fire? Examples of those conditions might include a failed
exhaust header gasket, loose exhaust component / fastener, growing hole in
the muffler or an exhaust pipe, or even a cracked cylinder.
A lot of real dangerous things can happen BETWEEN oil changes where they
could be easily spotted and it seems that such a detector could give a pilot
a much better chance of getting an airplane on the ground before a fire got
started by giving them some time to reduce power (which might prevent a fire
altogether) and head for the nearest airport to check things out. It sure
seems it might be several minutes that failures like those above could be
detected, and detected before they begin to catch things in the cowling on
fire around them.
I have done some checking and transport aircraft, some helicopters, and even
larger power boats have systems that detect excessive heat in their engine
compartments. Some discharge halon bottles, and some of those in boats even
shutdown engines (clearly not advisable on single engine aircraft).
Anyone know of an "affordable" and light weight detector for small aircraft
that might monitor the airflow near the bottom of the engine before it exits
the cowling or perform some other monitoring function to detect a condition
that could lead to an in-flight fire?
George
Old May 29th 04, 11:35 PM
George Sconyers
I have done some work on this problem and was hoping to get some feedback
from the group.
Anyone have any idea what an acceptable price would be to an aircraft owner
for a cowling fire detection / prevention aid described as follows:
Aircraft Cowling Fire Detection / Prevention Aid:
- battery powered temperature sensor / transmitter module for placement in
the cowling.
- battery powered temperature receiver / digital display module for
monitoring in the cockpit.
- very small transmitter in cowling with a remote 400 degree F temperature
sensor that has a short braided wire cord and a 6" thin aluminum rod so it
can be easily positioned in the air stream exiting the cowling towards the
back of the engine somewhere along the bottom of the firewall.
- small receiver in cockpit (like little kitchen timers used for IFR
approach timing) displays cowling air temperature at the sensor and can be
set to alarm (blinks / sounds tones) when pilot selectable temperature is
reached.
- placed in the airplane by the owner, not connected to aircraft power
supply or other wiring, no permanent mounting bracket, just "stuck",
"clamped", or "wire tied" on just like a portable VFR GPS, portable VHF
radio, IFR approach (kitchen) timer, or a CD player not requiring a Form
337.
- sensor / transmitter, receiver / digital display / alarm, 4 AAA batteries,
combined weight less than 1 pound
- change AAA batteries at oil change / annual etc.
Any feedback on functionality or acceptable pricing appreciated.
George
"George Sconyers" wrote in message
y.com...
detect
to
pilot
got
fire
fire around them.
even
even
aircraft
exits
condition
George
Old May 30th 04, 02:18 PM
Bushy
If you want to keep the price down, and you are not worried about
certification, you could use a home oven temperature probe. There are meat
temperature probes from cooking equipment suppliers and actual oven
temperature probes available through pottery places for kilns.
Some of these are selfcontained and the probe could be placed in a sensitive
area and the cable fed through to the cockpit or cowl mounted gauge. The
cowl guage could be read via the windscreen, or a mirror.
Some of these can be set to a certain temperature to turn off the oven when
the meat is cooked. This could be used to operate an "Idiot Light".
Hope this helps,
Peter
Old May 30th 04, 06:02 PM
George Sconyers
Thanks Peter! You are thinking right down the path I am currently on but
with a slightly different way to install it and to view the temperature.
So, if I negotiate with one of serveral existing manufacturers of an "oven
product" some of which I have already tested in my own turbocharged aircraft
to build it so it meets ALL the requirements of being in the cowling
(waterproof, electronics capable of handling the heat, etc. and some other
proprietary ideas...) and you could read your under cowl temperature on a
nice little digital display with an integrated "high temp" alarm in the
cockpit. What is the right price for a product that installs in 15 minutes
during your next oil change without running any wires through your firewall
or panel.
Anyone got an idea of what this might be worth to airplane owners?
$150?
$200?
$250?
Would this be something that pilot / owners would buy at their local pilot
shop or would the Internet be a more likely place to buy it, in order to get
a lot more info than can be put on the product packaging?
Interested in any thoughts anyone has on this.
George
Old May 31st 04, 02:40 AM
Jim Carter
The oven or meat thermometers are usually direct contact. Early in your post
you mentioned an ability to monitor via infrared to spot gasket blowouts,
etc. I don't see how a direct contact device will provide that feature until
the fire has broken out and it is too late.
Jim Carter
m...
aircraft
minutes
firewall
or panel.
$150?
$200?
$250?
get
George
Inside the Cowling Fire / Heat Detector? David Johnson Owning 2 June 2nd 04 09:48 PM
Inside the Cowling Fire / Heat Detector? George Sconyers Aviation Marketplace 4 May 31st 04 02:40 AM
Inside the Cowling Fire / Heat Detector? George Sconyers Owning 5 May 30th 04 08:04 PM
My Engine Fire!! [email protected] Piloting 21 April 2nd 04 06:02 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 02:41 PM
