With the demise of 80/87 avgas, I bought a gallon of TCP and will
start adding that to the 100LL that I must now buy. However, scouting around the internet I found something that claims to be similar in function but safer: decalin. Here's a blurb from Aircraft Spruce. My questions are, has anyone any experience with both decalin and TCP, and how do they compare? And, in spite of the last sentance below, can decalin be used beneficially in certified aircraft engines? "Scavenges Lead in aviation fuel after combustion to prevent lead oxide buildup on valves but still allows the lead to perform the anti-knock function prior to combustion. "It is an excellent additive for auto conversions, where it reduces buildup on oxygen sensors and plugs. If you have to use 100LL, then this stuff is for you. Prevents valve seat erosion from valve seat micro welding. It is equivalent to TCP. "Does not contain volatile solvents so it is safe to ship and safe in the cockpit. You can carry it with you for out-of-town airports. "Easy to use graduated measuring and dispensing resevoir built into the bottle. No messy syringes! "Tested and stable down to 0 degrees F. "Decalin TCP is not approved for use in the engines of certified aircraft." |
At Arlington the Aircraft Spruce salesman told me to watch for a new
product that was reputed to be better than TCP (a mute point really as nobody can find TCP for sale). So maybe this is it. I can't comment on Decalin but I can pass on one piece of information that many don't know. TCP themselves, and many knowledgeable sources, all say that you should never use TCP in a higher than 1000 TBO engine. NTSB reports site TCP (and MMO) as causes of accidents in high time engines, where crap has been dissolved/dislodged, and has then managed to stall an engine. I mention this just because I believe you should check if Decalin suffers from the same problems. HTH Tony C-GICE In article , Bob Fry wrote: With the demise of 80/87 avgas, I bought a gallon of TCP and will start adding that to the 100LL that I must now buy. However, scouting around the internet I found something that claims to be similar in function but safer: decalin. Here's a blurb from Aircraft Spruce. My questions are, has anyone any experience with both decalin and TCP, and how do they compare? And, in spite of the last sentance below, can decalin be used beneficially in certified aircraft engines? "Scavenges Lead in aviation fuel after combustion to prevent lead oxide buildup on valves but still allows the lead to perform the anti-knock function prior to combustion. "It is an excellent additive for auto conversions, where it reduces buildup on oxygen sensors and plugs. If you have to use 100LL, then this stuff is for you. Prevents valve seat erosion from valve seat micro welding. It is equivalent to TCP. "Does not contain volatile solvents so it is safe to ship and safe in the cockpit. You can carry it with you for out-of-town airports. "Easy to use graduated measuring and dispensing resevoir built into the bottle. No messy syringes! "Tested and stable down to 0 degrees F. "Decalin TCP is not approved for use in the engines of certified aircraft." -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
"tony roberts" wrote in message
news:nospam-298825.23052207092004@shawnews... TCP themselves, and many knowledgeable sources, all say that you should never use TCP in a higher than 1000 TBO engine. NTSB reports site TCP (and MMO) as causes of accidents in high time engines, where crap has been dissolved/dislodged TBO or SMOH? What about if you've been using it from the start? Paul |
![]() TBO or SMOH? What about if you've been using it from the start? At 1000 hours they are both about the same ![]() ![]() ![]() The advice I got was not to START using it on a mid to hightime engine, because of existing buildups which can dislodge. If they have been used from the start, and performed as advertised there shouldn't be any buildups. But personally I would ask the manufacturer first. Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
On 07 Sep 2004 20:39:22 -0700, Bob Fry
wrote: "It is an excellent additive for auto conversions, where it reduces buildup on oxygen sensors and plugs. If you have to use 100LL, then this stuff is for you. Prevents valve seat erosion from valve seat micro welding. It is equivalent to TCP. I am not a internal engine combustion expert, and don't play one on TV, but I have a couple of thoughts to add regarding this statement: The auto conversions I'm aware of tend to run cleaner than certified aircraft engines regardless whether they are carburated or fuel injected. This is because they normally run with a mixture closer to the stochiometric ideal than do the aircraft engines during the settings other than leaned for cruise. Most auto engine conversions do not have fixed timing. The timing adjusts as need be for the running condition. Some of them are using full fledged auto fuel injection and timing computers which vari the timing and fuel being injected many times a second according to the sensors. With the full boat conversions, those using all the sensors and computers, the timing and fuel mixture adjusts for all situations, including altitude compensation. Unlike fixed timing engines, this means the engines never get to the point where the peak pressure point approaches top dead center where the pressure increase can cause detonation at high power settings, because the computer keeps the timing adjusted to prevent that. Tixed timing engines MUST use the richer mixture for high power settings in order to retard the mixture's rate of burn so that the PPP does not occur with the piston at TDC. The rich mixture burns more slowly than a mixture that is close to ideal. With all this in mind, the auto conversions tend to run leaner mixtures most of the time which ,(this is where opinion raises it's head) should reduce lead buildup in auto conversions. Why? Because the nearly ideal mixture ratio results in near complete combustion. That's the way it looks to me anyway. Corky Scott |
Corky,
Bud just overhauled the heads on his Ford because it sat for a number of years in Florida. He has been using 100LL almost exclusively. The head shop found heavy lead deposits on the valves which they found difficult to remove (probably forgotten how). It may be that TCP or similar product is necessary in our Fords if we run avgas all the time. Corky Scott wrote: On 07 Sep 2004 20:39:22 -0700, Bob Fry wrote: "It is an excellent additive for auto conversions, where it reduces buildup on oxygen sensors and plugs. If you have to use 100LL, then this stuff is for you. Prevents valve seat erosion from valve seat micro welding. It is equivalent to TCP. I am not a internal engine combustion expert, and don't play one on TV, but I have a couple of thoughts to add regarding this statement: The auto conversions I'm aware of tend to run cleaner than certified aircraft engines regardless whether they are carburated or fuel injected. This is because they normally run with a mixture closer to the stochiometric ideal than do the aircraft engines during the settings other than leaned for cruise. Most auto engine conversions do not have fixed timing. The timing adjusts as need be for the running condition. Some of them are using full fledged auto fuel injection and timing computers which vari the timing and fuel being injected many times a second according to the sensors. With the full boat conversions, those using all the sensors and computers, the timing and fuel mixture adjusts for all situations, including altitude compensation. Unlike fixed timing engines, this means the engines never get to the point where the peak pressure point approaches top dead center where the pressure increase can cause detonation at high power settings, because the computer keeps the timing adjusted to prevent that. Tixed timing engines MUST use the richer mixture for high power settings in order to retard the mixture's rate of burn so that the PPP does not occur with the piston at TDC. The rich mixture burns more slowly than a mixture that is close to ideal. With all this in mind, the auto conversions tend to run leaner mixtures most of the time which ,(this is where opinion raises it's head) should reduce lead buildup in auto conversions. Why? Because the nearly ideal mixture ratio results in near complete combustion. That's the way it looks to me anyway. Corky Scott -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| |
On Thu, 09 Sep 2004 06:49:10 GMT, "Bruce A. Frank"
wrote: Corky, Bud just overhauled the heads on his Ford because it sat for a number of years in Florida. He has been using 100LL almost exclusively. The head shop found heavy lead deposits on the valves which they found difficult to remove (probably forgotten how). It may be that TCP or similar product is necessary in our Fords if we run avgas all the time. Well, there you a actual experience trumps conjecture most of the time. I humbly bow to the superior information. Ron, as to the oxygen sensor, some very clever people have managed to fake out the system by sending a trace voltage to the computer making it think the sensor is working. Don't know how the computer then knows how to adjust for all conditions when the signal to the computer from the O2 sensor is fake though. Having to fake out the computer, along with having to depend on the single source for your ignition AND timing is why I've chosen not to go that way. Well, that and not wanting to pay for injection capable heads and the fuel pump, rails, plumbing, injectors etc etc for a fuel injection system. Corky Scott |
Decalin instead of TCP? | Bob Fry | Home Built | 9 | September 14th 04 05:21 AM |
Decalin instead of TCP? | Bob Fry | General Aviation | 7 | September 14th 04 05:21 AM |
Decalin instead of TCP? | Bob Fry | Owning | 7 | September 14th 04 05:21 AM |
