For Sale - Used PowerFLARM Core v1
Old May 29th 14, 11:30 PM posted to rec.aviation.soaring
Paul Remde
Default For Sale - Used PowerFLARM Core v1
This is a great deal on a slightly used PowerFLARM Core v1. It looks almost
perfectly new, other than the scratches on the mounting feet. Version 1
Core units are exactly the same as the current version 2 PowerFLARM Core
units with the exception that the Audio Output hardware is not built-in.
The Audio Output hardware is only used to send beeps to an aviation headset
when the unit is used in a motorglider. Glider pilots would not need the
Audio Output because they will hear the traffic warnings from their remote
FLARM display or PDA.
This unit comes complete with all new accessories:
- PowerFLARM Core Manual
- PowerFLARM Tips document
- PowerFLARM Antenna Mounting Tips Application Note
- GPS antenna
- FLARM Dipole Antenna
- ADS-B Dipole Antenna
- DB-9 cable for power connection
- USB extension cable
The accessories are new because the owner needed the Audio Output
capabilities for use in his motorglider. I sent him the new version 2
PowerFLARM Core but kept the accessories for use with this version 1 Core
unit.
The latest PowerFLARM Core firmware version 3.4 has been installed. I will
also create and load a custom configuration file for you before shipment.
New PowerFLARM Core units sell for $1460. This unit has the optional IGC
Enable ($98), ENL Enable ($147), and FLARM B Antenna Enable ($54) keys
entered. The total value is $1759.
This system is available for $1395.
A logger altimeter calibration is available as a $75 option.
A remote FLARM display is not included. Several options are available. The
most popular option is the LXNAV FlarmView for $280.
Photos of this particular unit are available he
https://www.flickr.com/photos/remde/...7644500810257/
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Oudie2 - V7 - PowerFlarm Core setup (cabling question) ES Soaring 4 March 3rd 14 01:29 AM
Powerflarm Brick/Core ADSB Range Sean F (F2) Soaring 3 September 5th 13 04:10 PM
PowerFLARM core external display software update kirk.stant Soaring 5 January 28th 13 09:56 PM
powerflarm portable for sale [email protected] Soaring 0 October 23rd 12 04:32 PM
For Sale PowerFLARM Portable (USA) Andy[_1_] Soaring 0 September 17th 12 01:28 AM
