flarm flight log download through Oudie?
Old January 20th 15, 05:56 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default flarm flight log download through Oudie?
Yesterday I upgraded my Oudie to v6.11 and my V7 to v4.97 The Oudie is connected to the V7, and the V7 is connected to the flarm brick. I tried to access log files on the flarm via SeeYou's ConnectMe on the Oudie, but it failed as usual. It always recognizes the flarm device and is able to read the serial number, version, etc, but never able to download files.
Am I doing something wrong? (no, I don't remember which version of flarm firmware I am running, but it was upgraded last year)
Matt H.
Old January 20th 15, 08:48 AM posted to rec.aviation.soaring
I have the same behavior with my Oudie 6.1 and the Flarm 5.09 connected via a MUX from K6-Team. In flight modus, everything is fine in SeeYou, but ConnectMe identifies the Flarm, lets me have the flight list and subsequently hangs up.
Delogging the Flarm via SeeYou on a PC is fine, though.
I somehow suspect the Flarm data cable to be crappy or wrongly routed. I had a very similar problem with the CAI302: The original cable which came with the Oudie is quite long, so I wrapped it up and fixed it with cable tiers.. Same symptoms as above (SeeYou Mobile working fine, ConnectMe identifying the CAI, but no downloads). When I straightened out the cable, everything was fine...
Old January 20th 15, 09:42 PM posted to rec.aviation.soaring
Paul Remde
Hi Matt,
PowerFLARM products do not support the download of flight logs through the
serial port. They never have and they probably never will. Using a USB
flash drive is much faster and (in my opinion) easier.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
__________________________
"Matt Herron Jr." wrote in message
Matt H.
Old January 21st 15, 03:28 AM posted to rec.aviation.soaring
Matt Herron Jr.
Best Regards,
Paul Remde
Thanks Paul.
Sounds like the difinitive answer.
Matt
IGC Flight Recorders using Flarm firmware - New DLL file forvalidating IGC flight data files Ian Strachan Soaring 0 July 20th 14 08:28 PM
Oudie download of task to CAI302 [email protected] Soaring 4 July 17th 13 11:22 PM
FLARM-V7-Oudie setup dbrunone Soaring 10 July 9th 13 09:27 PM
CAI 302; slow download of flight log BillT Soaring 9 November 8th 11 05:40 AM
Flight download Steve Freeman Soaring 8 June 19th 07 11:01 PM
